custom dash 5 gauge pod - Ford Powerstroke Diesel Forum
Old 03-12-2012, 06:29 PM
i have the pillar pod with the essentials. (Tranny temp,EGT,Boost)
i also have a oil psi,oil temp,coolant temp,fuel psi,and HPO guage.
could never come up with a suitable option to mount them so here is the start.
pic 1,2 heated a pc of plastic sheet in the oven @ 350 for about 5 min till it was pliable. then i molded it to the dash where i plan on putting it.
pic cut 5 pc of plastic 2" pipe to hold the shape intended.
pic 3,4 positioned the pvc where i wanted it and the desired configuration. then proceed to secure with hot glue.
pic 5,6 after the glue cooled i used an old t-shirt and hot glue to acchive the desired shape.
pic 7,8,9 after the fabric is in place i test fit and prepare to glass in. that will follow in a few days.
custom dash 5 gauge pod-027.jpg   custom dash 5 gauge pod-028.jpg   custom dash 5 gauge pod-029.jpg   custom dash 5 gauge pod-030.jpg   custom dash 5 gauge pod-031.jpg
Old 03-12-2012, 06:34 PM
2nd go on pics
custom dash 5 gauge pod-032.jpg   custom dash 5 gauge pod-033.jpg   custom dash 5 gauge pod-034.jpg   custom dash 5 gauge pod-035.jpg
Old 03-12-2012, 06:58 PM
Feedback Score: 3 reviews
subd to see this one through
Old 03-12-2012, 10:58 PM
that looks awesome, i would have spaced the base 3 to bring the top 2 down a bit farther so as not to be so tall, but your work looks great so far, its a nice use of the retarded blank space on the obs dash, btw is that a pioneer deck there? what kind is it?
Old 03-12-2012, 11:22 PM
Subscribed to see this through as well. Good idea you have there. I'm with the other guy to I would have did the little more space on bottom three to make it not stand so tall. But it looks really good at the moment. I would be happy with the work if I did it.
Old 03-13-2012, 06:46 PM
got one coat of glass resin on it. tomorrow i will sand it down some coat again. then this weekend i will finish it with some body filler, skim with glazing putty and grain it then paint.
or i will try wrapping it in vinyl . but i believe it will be difficult with all the complex curves.
the latter sounds more difficult so i will try it first.
Old 03-13-2012, 07:17 PM
I would paint it cuz yes vynil would be difficult to wrap all those curves not impossible though. I'm ready to see the finished product
Old 03-13-2012, 07:19 PM
Oh yeah just curious how are you going to anchor it down. Or does it sit so well that it wont move around?
Old 03-13-2012, 07:49 PM
velcroooooooooooooooooooooooooooooooooooooo
