CB Problem
I hace a CB mounted in my 6.4 and obs and both stopped working. They both turn on but i don't hear anything. I have moved all the dials switches and nothing. I have the CB where you can get the weather on it i can hear the weather fine but i can't hear any static from the cb and or people talking. I even had my friend try to see if he can get it to work and he had no idea. Let me know what you think i should do..
They are both less than a year old. Tom |
Google cb shops in your area. They are usually near truck stops. You may have fried the cb due to the antenna is not matched to the radio. You want to have as close to zero to zero match from 1-40 on the channels. Usually cb shops will match the radio 1:1 on channel 1 and 40. After that they will work for ever.
What brand cb and antenna are you running. |
Both CB's are Cobra 29 BT with weather and night watch. Im using a magnetic mount antenna for both trucks. I picked the Antennas up at the local TA truck stop.
Tom |
what brand antenna are they. If they are some cheap antenna and weren't matched to the radio. If you used your radio a lot most likely you fried the board.
They where some 30.00 magnetic antenna from a truck stop. No idea on the brand. How will i know what CB antenna will work for that radio?
Where did you mount the cb in the 08?
Right in front of the center console where the cup holders are. I really didn't want to drill the console but i made 2 small holes but it looks awesome.
Tom |
There is more to a cb radio set up then just hooking up the radio and attaching the antenna to it. It needs to be ( matched or Tuned ) which is what I talked about earlier. Usually they use an external SWR Meter. It is hooked between the radio and the antenna. Then you make adjustments to the antenna til you achieved the 1:1 match between channel 1 and channel 40. Sometimes the coax is shortened or extended or just a simple adjustment of the antenna up or down in the mount. Really if you have not done this before then you should have an experinced person do it. |
Tom |
I would do as I recommended in my first post. Google CB Shops in your area. I know there has to be at least one around. Truckers still use CB radios |
