Xl doors to xlt with power locks and Windows - Ford Powerstroke Diesel Forum
Old 01-13-2012, 05:21 AM
Obviously I'm thinking about converting my 97 xl to power doors, does the harness have a plug in for these? Figured I would ask before buying the parts to do this
Sent from my C771 using AutoGuide.Com Free
Old 01-13-2012, 09:19 AM
The wiring is not in the truck. You will need both door harnesses. The drivers door harness runs behind the dash all the way across the truck. You will also need to add a ground wire, and power wires for the locks window and courtesy lights in the truck harness that runs from the dash harness to the door harness on the drivers side. My truck had the power wires run in the dash harness. The window motor and lock soledoid bolted right in on mine.
Old 01-13-2012, 02:43 PM
Here's where the harness goes...
You may need the white clips, being a PSD, it might already have the full firewall insulation, unlike XL gas trucks that have only a partial insulation panel.
Like the Fordboyrod stated, it's one long harness and removal of the driver door isn't as easy as the passenger side.
Green square is where it connects to the factory dash harness for power, speakers, courtesy lamps etc.
Yellow square is the connection to the left door harness.
Old 01-14-2012, 11:48 PM
i remember this from ofs lol, this ties into the op's original question, if i want to add power mirrors, where does this harness plug in at? i need one to go with my mirrors that i recently installed
Old 01-15-2012, 02:47 PM
Worst thing is, I had to grab that pic from the net since it isn't on my computer.
You'd have to find the right and left harnesses with power mirrors if the connections aren't there already.
Old 01-17-2012, 09:12 AM
Do you have any of the door harness for the mirrors?
Old 01-17-2012, 09:48 AM
negative, i need to go pull some, morethan likely from an f150 or bronco
Old 01-17-2012, 06:47 PM
Double check to see if the truck harness has the power wire you need. As long as you are getting parts you may want to get that section of harness. I have a wiring diagram for the mirror system if you run into any questions.
Old 01-17-2012, 08:11 PM
awesome, i have to wait a few days to hit the yard tho, mite go with john
Old 07-22-2012, 11:38 AM
does anyone know what color harness wires are for the lock, and window motor so that i can wire them upwith a hot n a ground and not burn my truck to the ground lol
