how to hook up boost gauge in 97 350 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-03-2007, 07:22 PM Thread Starter
cowboymafia's Avatar
Send a message via AIM to cowboymafia
im stuck trying to find out where to tap in to plug in my boost gauge an would love some help
1996 dodge 3500
the new toy
cowboymafia is offline
post #2 of 7 Old 09-03-2007, 07:28 PM
Beer Drinker/Ballast Guy
clmtng's Avatar
You're going to need to cut the mapline and put it there. I had to go to AutoZone to get a different T piece since the one that came with my gauges wasn't big enough to fit in the line. You need a 1/4 inch T. I'll see if i can find a picture of the location of the map line for ya. It's basically on the passenger side, running from a small black box to the x-pipe. I did some searching through different gauge makers and found it that way.
99.5 F-250; Garrett GTP38BB Turbo; 4" MBRP Exhaust; 2" Leveling Kit; AEM Air intake; ZooDad Mod; Foil Delete; AutoMeter Z series gauges, pyro, boost, trans. temp w/piller pod, muffler delete, Tunes by Tony Wildman; Recon tail lights and third brake light; Headlights from Raul; Twinkle mod // Soon to be: winch
clmtng is offline
post #3 of 7 Old 09-03-2007, 07:39 PM
clmtng's Avatar
Here is a link for ya that has pretty detailed instructions on putting that sucker in. It's not too hard. Some of the threads I've looked at say that you can drill and tap into the intake elbow, but this is so much easier and those threads are mostly speaking of 6.0s.
Good luck.
http://www.dieselmanor.com/docs/Boos...ation-rev4.PDF
clmtng is offline
post #4 of 7 Old 09-03-2007, 07:42 PM
Mavsps's Avatar
Or if you plan to drill and tap, drill into the black peice that comes off the front of the turbo..... BUT TAKE IT OFF TO DO IT!
05 powerjoke extended cab.
Sct tuned by innovative
Open downpipe
Traction Bars and Suncoast on the way!
96 powerstroke extended cab 7.3
4x4 393000 miles
2005 duramax lly edge/predator stack
14.3 1/4 mile 2.3 60ft roasting tires
limping the trans at 1000ft
Mavsps is offline
post #5 of 7 Old 09-03-2007, 07:44 PM
willypscustoms's Avatar
or do the aih delete and use that for boost tap in
here are pics of it
http://www.dfuser.com/mfg/powerstroke/73/Intake/AIH.php
IF CAPS ARE ON IM AT WORK I CANT TAKE THEM OFF
willypscustom cold air intake
4" exhaust straight piped
banks 6 gun
itp regulated return
dp tuner
9" lift 37" tires
agr hydro. assist steering
greddy turbo timer and greddy gauges
wicked wheel
and some other small mods
willypscustoms is offline
post #6 of 7 Old 09-04-2007, 06:19 AM Thread Starter
great thank you all
1996 dodge 3500
the new toy
post #7 of 7 Old 09-04-2007, 02:13 PM
Mavsps's Avatar
I brazed a fitting on mine to make it easier
Open downpipe
4x4 393000 miles
Mavsps is offline
