no cold air.. any help - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-05-2011, 05:31 AM Thread Starter
F3507.3POWERSTROKE>cumins's Avatar
i got a 03 350 and the ac has worked for the ten years ive had it but just went out a couple weeks ago.. im pretty sure the clutch is bad in it because when the ac shuts off ive gone out under the hood and checked it out and the clutch on it (idk if its the clutch that pops out but its like that black dish on the front of the compressor) is popped out, but if i hit it with something and pop it back in then the ac will turn on again but not for long.
just wonderin if i should get a whole new compressor or what..
thanks
F3507.3POWERSTROKE>cumins is offline
post #2 of 9 Old 10-06-2011, 03:43 AM
Unreal706's Avatar
had the same problem in my 2001 f250, cold air would not start until i was going down the road, but im not sure what to tell you... maybe ask a senior member
Unreal706 is offline
post #3 of 9 Old 10-06-2011, 03:49 AM
cweiss87's Avatar
Before you go buy a compressor check and see if your getting power to the compressor. If no power to the clutch then you have another problem. Could be low charge, bad switch or other things if you have no power to the compressor clutch. Make sure key is on engine running with a/c set to on or max a/c when you test
04
F-250 FX4.
Sct X2 with tunes from Gearhead
Zoodad mod
High idle mod
Straight pipe exhaust
BDS leveling kit
Stage 1 intake
cweiss87 is offline
post #4 of 9 Old 10-06-2011, 06:27 AM Thread Starter
ya , thanks .. im gunna check it out and if i cant fiure it out i know i guy that can hook me up and tell me wats wrong with it
but thanks
post #5 of 9 Old 10-08-2011, 08:23 AM
CCLBpsd's Avatar
Sounds like it's low on charge, there is a low pressure switch which disengages the clutch to prevent freezing/damage to the compressor from running flat. As stated before it could also be a bad switch or clutch.
CCLBpsd is offline
post #6 of 9 Old 10-08-2011, 09:20 AM
jesilvas's Avatar
Quoted: 3 Post(s)
There is a high/low pressure safety switch. Check your air gap. As any clutch does, it wears down to a point so that they won't engage. You have to remove some spacers in between the clutches and then it might work better.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 9 Old 10-08-2011, 09:28 AM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
thanks
Woah....Wait a sec here
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #8 of 9 Old 10-11-2011, 08:51 AM
TexasAggie09's Avatar
You might get more help with your problems if you posted them all in the correct forum.
Don't be hitting the clutch with a hammer. Check your charge first. Sounds low to me. Recharging mine and replacing the orifice tube solved all my problems. Good luck.
Thanks and Gig 'Em!
White 1995 F350 CC LB 4x4 7.3 SRW
Bought 8/27/09 with 183k miles
4 Position Chip, 35" BFG Mud Terrains, Bilstein 5125 Shocks, DIY Intake 6637, No cat/muffler, Carr Side Steps, Ranch Hand Front Bumper, Headache Rack, Rear Bumper
Fightin' Texas Aggie Class of 2009
TexasAggie09 is offline
post #9 of 9 Old 10-11-2011, 08:12 PM
CCLBpsd's Avatar
TexasAggie09 You might get more help with your problems if you posted them all in the correct forum.
^key point^
CCLBpsd is offline
