LED light conversion. ALL of the bulbs. W/PIX
SO im converting this truck to all LEDs.
ordered a bunch of 194 LEDs, which are the main bulb for this rig. Im replacing: Exterior: rear tail light bulb (2) rear reverse bulb (2) rear license plate bulb (1) cab brake light bulbs (3) DUally Marker light bulbs (4) Cab light bulbs (5) Front Blinker bulbs (4) front marker bulbs(2) Front headlights (replace evuntually with HIDs) (2) Interior: Gauge CLuster BUlbs (16) door panel illumination bulbs (4) dome lights (6) (frnt&rear) glove box (1) ash trey (1) Climate control (?) 1-3 mosty of these bulbs are 194 and 3157, & 9007 for headlights. I ordered off of ebay. IDK when theyll be here. But i also ordered some WHite LED strobes (18) of em for cheap let me no if you need info or questions SO far whats done is FRONT LED foot pedal (Driver and pass) lights. and underhood led strips with switch. ![]() ![]()
Ive been thinking bout doing this. Ill keep tuned with this and see how it goes.
Man, how big of a PIA was it to wire all those? Or was a lot of it existing? Looks good tho!
The only wiring ive done is The under hood light and foot lights. wasnt to bad. I put a jam switch in the hood and ran it up thru the holes. Then wired the Pedal lights to the door jam switch
Got 4 outta 6 of my 3157 White LED bulbs in (: ill test em tommorow.
That looks killer man! Intrested to see what the difference the led's make inside. Good work! Might just have to be the next thing I do
look freakin sick i was looking into upgrading all my lighting but first is fixin the GPR and Clutch linkage
Where did you get those 3157's? I like the look of those. How much did all the bulbs set you back?
Hey Gabriel - Just letting ya know, you will need load resistors or a flasher for LEDs. If you don't do either, you'll the 'fast-flash' syndrome. Stock flasher is set up for a certain load. LEDs are much less of a load than regular bulbs so the flasher 'fast-flashes' indicating what would normally be a burned out bulb.
See this link: eBay Guides - Load Resistor Use With Automotive LED Bulbs My tails have the resistors built in, but I changed to an electronic flasher when I put my from 3157-A bulbs up front. |
I switched all my lights over to LED also best thing I ever did!
