Purchasiong Clutch and other parts - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-23-2014, 09:34 AM Thread Starter
pk64f100's Avatar
I have found many vendors selling what appears to be the same clutch kits,Who do you buy clutch from and are you happy with their service? Thanks
pk64f100 is offline
post #2 of 10 Old 08-24-2014, 04:45 AM
Indeed the choices can be dizzying. I think many of vendors that show up on this forum are good (DieselSite, Stealth Auto, Riff Raff, etc.). I would personally contact Cary at CT Performance and get his opinion. I don't know if he sells clutch components. If he does, they'll be good components. If he doesn't, he'll be able to point you in the right direction.
1996 F350 4x4 CCLB E4OD
Stage 1's, Tony Wildman Tunes, 6637 Intake, 5" Stainless Exhaust, Bilstein 5100's, FPR Spring Mod, Dark Blue CPS, Pillar Gauges (trans temp, pyro, boost), 6.0 Fan Mod, Tru-Cool Max Trans Cooler (and SD Cooler Lines), HPX Crossover, Alum Radiator, 203 Deg DieselSite Thermostat, '08 SD Alum Finned Rear Diff. Cover, PMF RSK (w/ V-Codes)
majorgator is offline
post #3 of 10 Old 08-24-2014, 10:09 AM
+1
Cary is awesome. He will gladly help you out.
Rashole is offline
post #4 of 10 Old 08-26-2014, 05:04 PM Thread Starter
pk64f100's Avatar
Perfection Performance Clutch kits
Has anyone experience with the Perfection Performance Clutch kits? They are sold at our local Advance Auto. they say their quality control is 2nd to none and I need to hear from people 1st hand before I buy. Thanks
pk64f100 is offline
post #5 of 10 Old 08-26-2014, 07:10 PM
dr.deere's Avatar
Quoted: 19 Post(s)
You get what you pay for. I personally have luk in both trucks and when I decide it's time to play they get severely abused. Never had an issue
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #6 of 10 Old 08-27-2014, 03:47 AM Thread Starter
pk64f100's Avatar
That is exactly what I ordered last night from Carolina Clutch the LUK conversion kit to single solid FW. Thanks
pk64f100 is offline
post #7 of 10 Old 08-28-2014, 01:54 PM Thread Starter
pk64f100's Avatar
My clutch is coming tomorrow and I asked my regular mechanic for a quote and he told me $600, it sounded steep, i sure wish i had a lift, jacks and a healthy back / spine and I would do it my damm self but that aint happening so i am shopping around calling everyone trying to find someone more reasonable. I have been told it is a 3-4 hr job so at $100 hr that would be $300 - $400 and that seems like high but more like it, I am not a cheap-skate just hard working construction sup't that doesn't make a mint. This sucks eggs I aint paying $600 for a clutch install.
pk64f100 is offline
post #8 of 10 Old 08-28-2014, 03:22 PM Thread Starter
pk64f100's Avatar
Flywheel conversion
I was purchasing my new LUK clutch FW conversion kit and it appears that once you swap out the Dual mass FW with the solid single FW you can purchase more performance clutches when you up torq and hp and just keep the FW with getting it resurfaced if needed. Has anyone any info on the LUK solid FW and upgrading clutches after time, do the flywheels last and can they handle more torq / hp without buying a different type? TY
pk64f100 is offline
post #9 of 10 Old 08-28-2014, 04:58 PM
dr.deere's Avatar
Quoted: 19 Post(s)
Between my brother and I we have been running luk for 10 years. He has a banks chip and I've used edge for tunes in the past all while sled pulling and normal working. I've had the flywheels resurfaced a couple if times they seem to hold up good.
dr.deere is offline
post #10 of 10 Old 08-29-2014, 04:10 AM Thread Starter
pk64f100's Avatar
TRhanks, I think I bought the correct one then it is called the heavy duty LUK conversion kit with solid FW. Worse case I will have to up the clutch when time comes I am running TS 6 pos chip, AB intake and baby swamps 150/146 I believe.
pk64f100 is offline
