wanting a REAL fix for my Glow Plugs - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-22-2014, 09:13 PM Thread Starter
Dutter's Avatar
95 7.3 turbo. And when i got the truck the guy had a hot wired the controll side of the glow plug relay with a button. Well id like to get ride of that and fix it right. So when i key on my truck the wait to start light will come on for a fews seconds then go away, hot or cold. So that circuit is working sooo would it be the timer switch or some other part that i can look into ? And heres the relay i have a arrow pointing to a connecter that i think is meant to be hooked up to the relay http://www.powerstroke.org/forum/att...1&d=1408770819
Dutter is offline
post #2 of 10 Old 08-23-2014, 03:32 AM
If you buy motorcraft part# dy860 it will come equipped with the required pigtail to be plug n play
POWER-STRUCK is offline
post #3 of 10 Old 08-23-2014, 11:39 AM Thread Starter
Dutter's Avatar
ok cool thanks, and what dos that part go to ? like what electric component
Dutter is offline
post #4 of 10 Old 09-02-2014, 03:54 AM
Quoted: 3 Post(s)
I like the manually controlled plugs. While the heat is needed for a cold engine, using the plugs when starting a warm engine is a waste of battery energy and plug longevity.
Airstreamer67 is offline
post #5 of 10 Old 09-02-2014, 08:23 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
The engine also believes its "a waste of battery energy and plug longevity" as well. The WTS light has no bearing on how long the gps are actually on. Read the attached and you will see why.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #6 of 10 Old 09-02-2014, 08:47 AM Thread Starter
Dutter's Avatar
yeah true but iv read that they also stay on to help it warm up even it its already started, and how do i really know how long i need to hold that button down for
Dutter is offline
post #7 of 10 Old 09-02-2014, 09:24 AM
Chapter Director
Quoted: 5 Post(s)
You dont thats why the PCM is supposed to control it. Manual overrides are back in the days of IDIs. No use for that nowadays, just let the PCM do what it was designed to do
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #8 of 10 Old 09-02-2014, 05:52 PM Thread Starter
Dutter's Avatar
yeah exactly thats why i want it fixed and work how its suppose to and not have me guessing
Dutter is offline
post #9 of 10 Old 09-02-2014, 06:05 PM
Chapter Director
Quoted: 5 Post(s)
Well shoot me your email and ill send you a ton of stuff including wire diagrams to help fix the POs stupidity
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #10 of 10 Old 09-02-2014, 07:40 PM Thread Starter
Dutter's Avatar
haha will do thanks 530.dutter@gmail.com
Dutter is offline
