Not happy with EGT - Ford Powerstroke Diesel Forum
post #1 of 19 Old 08-21-2014, 07:22 PM Thread Starter
Not happy with EGT
Not real happy with my EGT's. Alliant stage one injectors that were installed about 60,000 miles ago by previous owner. I am running around 4 to 600 cruising around town, but even the slightest he'll will bump me to 900-1100 depending on how long the hill is. Going up a good-sized sustained hill I will have to lay back to about 40 mph to keep from hitting 1250 to 1300. I seem to be lacking low end boost. But that may be my imagination. Going up a moderate hill at 35 I might see 2-5 PSI. If I mash it getting on the freeway I will get 20-22 psi out of it. I have a 3 inch downpipe to a 4 inch exhaust with no catalytic converter, but does have a muffler. I recently replaced the up pipes and gaskets. Other than that nothing else I can think of. It does have a very slight lope at Idle. And I mean slight. But don't know if that is a fuel delivery issue that may contribute to the high EGT's or not. I am going to test for a boost leak this weekend, but would think I wouldn't be hitting 22 PSI if I had a leak, would I? Any help is appreciated.
1995 F350 CCLB 238,000 miles
4.10 Limited Slip
285/75/r16
S&B intake
3" down pipe/ 4" exhaust Straight Piped
EBPV delete pedestal
BeerBeer1911 is offline
post #2 of 19 Old 08-21-2014, 07:57 PM
Quoted: 8 Post(s)
I had the same problem with my Swamps. Put the trailer on the back and I couldn't go up a hill over 30mph not because I didn't have enough power but because I was running at 1300 and was afraid to go any higher. I tested and had no leaks. I installed a 1.0 turbo exhaust housing and that helpt a lot. It got the boost up higher at lower RPM and got my temps back under control. Before I couldn't use anything but a stock tune towing and would still get too hot. Now I can use a tow tune and have to push on it to get it 1300. I think some different tunes will finish off my problem. I have even thought about a water meth system triggered by EGT so it would cool me off on the toughest hills.
1997 Crew Cab Long Bed 4X4 (DRW Conversion) Auto. 280K miles
Stainless Irate Bellowed Up Pipes
Fresh Turbo with 1.0 Housing & Wicked Wheel II, 3" downpipe with 4" exhaust, Intercooled, 6.0 Fan, 39 gal rear fuel tank + 70 gal Transfer Flow in the bed, Hydroboost, Completely New Suspension (Springs, Shocks, Bushings),08 Rear Diff Cover, Baby Swamps, Hydra Chip with Swamps Tunes, and Swamps IDM, Dually Swap, Tru-Trac locker in the rear, Red Head Steering Box and Borgeson Steering Shaft
ChallengerRV is offline
post #3 of 19 Old 08-22-2014, 12:26 AM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
stage 1's? im not to big on injectors but more fuel means more heat , depending on what speed your going when im running around doing 40-45 im running at about 550-600 , you can run 1250 all day long , but over 1300 and your chancing it , if your truck is tuned your also gonna have high egt's.
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #4 of 19 Old 08-22-2014, 12:52 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Unless your EGT probe is post turbo what are you worried about?
4-600 cruising is normal. And you can run 1250 all day long as long as your probe is in the drivers side exhaust manifold.
Whose tuning and what turbo?
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #5 of 19 Old 08-22-2014, 05:49 AM Thread Starter
Just looked back through the paperwork and it looks like the previous owner actually installed AA stock injectors. But, I am not actually worried as much as I feel like they jump to the high end of the scale to easily. When I hit 1250 going up a moderate hill at 50 mph unloaded before throttling back I wonder. As far as I know from the previous owner there is no chip, but I am having it re-flashed on Monday to make sure it is a stock program. Just gets tiring having to watch the gauge every time I take a hill. Even at a 5% grade my temps will go from 600 to 1100 in 1/25 of a mile.
4.10 Limited Slip
285/75/r16
S&B intake
post #6 of 19 Old 08-22-2014, 07:06 AM
sbluke55's Avatar
Quoted: 548 Post(s)
Garage
I would check your up pipes for leaks and your exhaust manifolds. Also check for boost leaks. I know it's only a short distance but it's worth a look.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #7 of 19 Old 08-22-2014, 02:39 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
You have some sort of program to see 22psi
Stock is 17
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
post #8 of 19 Old 08-22-2014, 03:30 PM
dr.deere's Avatar
Quoted: 19 Post(s)
Stock is 17
If it's a manual it will hit 22 no problem on stock tuning. I know because I have two trucks with manuals and stock tuning that will hit 22 psi under the same conditions he said. In fact with a trailer on running it 3k rpm I can get my 97 to 25psi with a 1.0 housing.
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #9 of 19 Old 08-22-2014, 03:59 PM Thread Starter
Its an automatic, still has the original E40D. Cant speak yet as to a tune, but it definitly flutters between 20 and 23 psi. I have a casual friend that owns a Ford shop who didnt believe me till he took it out. His thought was a chip, however I am certain it is not chipped. Tune, like I said, not sure of yet.
4.10 Limited Slip
285/75/r16
S&B intake
post #10 of 19 Old 08-22-2014, 06:39 PM
dr.deere's Avatar
Quoted: 19 Post(s)
I don't have any experience with the autos but I know the PCM doesn't start to defuel until 22 psi. And if you can the rpm up in that 3 k range to be at full fuel they will boost that high
dr.deere is offline
