Driver Side Door Switch dosent work - Ford Powerstroke Diesel Forum
post #1 of 14 Old 08-21-2014, 01:08 AM Thread Starter
All the other door switches work except the driver side switch. It only works when i manually turn the interior lights on idk if its a bad ground wire. I just would like to know if there is anything else i can do or if i should follow the entire length of wire through the truck. If anyone has any ideas please feel free to leave them thanks.
nova1972 is offline
post #2 of 14 Old 08-22-2014, 01:12 AM
Subscribing
I have the identical problem.
1996 F350 4x4 CCLB E4OD
Stage 1's, Tony Wildman Tunes, 6637 Intake, 5" Stainless Exhaust, Bilstein 5100's, FPR Spring Mod, Dark Blue CPS, Pillar Gauges (trans temp, pyro, boost), 6.0 Fan Mod, Tru-Cool Max Trans Cooler (and SD Cooler Lines), HPX Crossover, Alum Radiator, 203 Deg DieselSite Thermostat, '08 SD Alum Finned Rear Diff. Cover, PMF RSK (w/ V-Codes)
majorgator is offline
post #3 of 14 Old 08-22-2014, 05:17 AM
Quoted: 53 Post(s)
Did you test the switch, removed from the circuit, with an ohmmeter or continuity tester? If so, what was the result? Did you test the circuit by removing the switch and jumpering the connector? If so, what was the result?
madpogue is offline
post #4 of 14 Old 08-22-2014, 09:13 PM Thread Starter
i did test it i only get power when i manually turn the interior lights on when there off i get nothing im currently following the wires where they go so im not sure yet the switch does work when manual power is turned on all the other doors work im not sure if its a bad wire or something else
nova1972 is offline
post #5 of 14 Old 08-22-2014, 10:01 PM
Quoted: 53 Post(s)
If you're tunring on the lights "manually" (presumably using the headlight switch), then you're bypassing the door switch, which means it has no bearing on whether the switch works.
What were the results of the two independent tests mentioned above?
madpogue is offline
post #6 of 14 Old 08-24-2014, 11:12 AM Thread Starter
yes i tested the switch directly i get no power
nova1972 is offline
post #7 of 14 Old 08-24-2014, 12:12 PM
Quoted: 53 Post(s)
Testing a switch does not involve power. Did you test it for continuity?
madpogue is offline
post #8 of 14 Old 08-28-2014, 04:13 PM Thread Starter
i tested the wires with a multimeter and i dont get continues power do you think its another switch or wireing problem
nova1972 is offline
post #9 of 14 Old 08-28-2014, 05:30 PM
Quoted: 53 Post(s)
Did you test the SWITCH (with NO WIRES connected to it)? If you didn't you're chasing your tail.
madpogue is offline
post #10 of 14 Old 08-30-2014, 03:15 PM Thread Starter
I dont understand test it with no wires how am i supposed to test something electrical with no wires i tried another switch from one of the other doors and it does the same exact thing so please elaborate on what u mean.
nova1972 is offline
