Cant get off muffler? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-20-2014, 07:40 PM Thread Starter
Purchased the truck with 4" MBRP cat-less exhaust with muffler. How in the hell do you get the muffler out? I freed the nuts on the hangers, but cant get the tailpipe hanger out of the bushing, not can I free the muffler from the inlet and outlet piping. Any tips or tricks to get this thing out. I have a delete pipe I want to try out.
Thanks.
1995 F350 CCLB 238,000 miles
4.10 Limited Slip
285/75/r16
S&B intake
3" down pipe/ 4" exhaust Straight Piped
EBPV delete pedestal
BeerBeer1911 is offline
post #2 of 7 Old 08-21-2014, 04:33 AM
Quoted: 22 Post(s)
a big hammer, heat and penetrating oil…. or a saw if its been on there for a while.
I've never had luck taking exhaust apart without destroying something
Syndicated_cdn is offline
post #3 of 7 Old 08-21-2014, 06:06 AM Thread Starter
Thanks. I will give it another go. Trying to preserve things in case the straight pipe is too obnoxious. However, I am thinking about going straight pipe and a FTE resonator further up to kill some drone. So, I guess if I screw it up then I will just have to go that way.
4.10 Limited Slip
285/75/r16
S&B intake
post #4 of 7 Old 08-21-2014, 04:45 PM
Quoted: 22 Post(s)
I ran my truck for a week with just my down pipe, nothing else. It was only noisy at WOT, sounded good actually. Id have considered keeping it if i didn't get smoked out at every stop by the fumes…
I think you'll like straight pipe
post #5 of 7 Old 08-21-2014, 05:40 PM Thread Starter
That is what I am hoping. I have the kids in there every once in a while so I don't want it to hurt their ears, but right now it is too quiet in my opinion. Wouldn't mind a little drop in EGT either. Just have to get the damn thing off!
post #6 of 7 Old 08-21-2014, 06:08 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Just cut it off and run the straight pipe, it will be quiet enough for the kiddos, I used to have stacks and the drone would put the kiddies to sleep every time, now I kinda miss them
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #7 of 7 Old 08-21-2014, 07:13 PM Thread Starter
Yep. Might just as well have to do that. Tried again tonight it's not moving. Was hoping for it to be a bit easier, since technically here in California you're not supposed to remove a muffler. But had a nice long chat with the CHP friend of mine. He kind of made my mind up to just give it a go. But if I do get jammed up, was hoping to be able to easily throw the muffler back in. But that's looking like a pipe dream. No pun intended
4.10 Limited Slip
285/75/r16
S&B intake
