Electrical problems - Ford Powerstroke Diesel Forum
post #1 of 8 Old 08-20-2014, 06:01 PM Thread Starter
aaklingler's Avatar
Electrical problems
On my 95 f350 I am having a rear window that works sometimes but not all the time. I am also having trouble with the power door locks, they do not work at all and when I hit unlock the module clicks that is behind the little compartment in the dash with 3 plugs going to it and the parking lights come on. Can anybody tell me what this module is or tell me what is causing my problems or how to fix them?
1996 F350 CC 4x4 auto 196k DIY intake
2002 Excursion 4x4 255k 160/80 66mm gtp38 intake and exhaust
aaklingler is offline
post #2 of 8 Old 08-20-2014, 06:32 PM
Quoted: 21 Post(s)
time to break out the volt-meter, and the wiring diagram
see this:
1996 Bronco/F-Series Workshop Manual
Syndicated_cdn is offline
post #3 of 8 Old 08-20-2014, 06:41 PM Thread Starter
aaklingler's Avatar
I was afraid of that
post #4 of 8 Old 08-21-2014, 06:09 AM
the baconator
terryknight's Avatar
Quoted: 141 Post(s)
the power window sounds like an intermittent power/ground problem. check where the wires run through the door you might find a cracked or broken wire. the rear doors are known for breaking wires. then follow the wires.
do you have an alarm on the truck?
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is online now
post #5 of 8 Old 08-21-2014, 06:29 AM Thread Starter
aaklingler's Avatar
As far as I know it doesn't have an alarm, what for factory theft system is there? Any idea what the black box is that says attention that is clicking?
post #6 of 8 Old 08-21-2014, 07:13 AM
the baconator
Quoted: 141 Post(s)
no idea. i was thinking aftermarket alarm. you have a picture?
post #7 of 8 Old 08-21-2014, 09:32 AM
Quoted: 44 Post(s)
The '95s (the only year, IIRC) did have an anti-theft option. Arming/disarming information is in the owner's manual. I think it also ties in RKE.
madpogue is offline
post #8 of 8 Old 08-21-2014, 11:02 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The black box with 3 plugs you described sounds like the rke module, it won't have anything to do with the window, but that may be your lock issue, is it 1 grey plug and 2 black ones?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
