What is the port in the back of the PCM actually for? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-19-2014, 08:43 PM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Obviously i know its where all performance chips go but i was wondering the other day what Ford actually put it there for. Back in 1994 there was little if any modifying diesels electronically so it wasnt designed with performance chips in mind and its something ford would be appalled at the idea of doing.
It seems like its something that would be used for troubleshooting but i cant imagine they would put the silicone over it that would require ford to have to clean it in order to communicate with it but ford has done weirder things.
Anyone know the real origin of the ports purpose?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 3 Old 08-20-2014, 07:18 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 49 Post(s)
I believe that it's sole intended purpose was to flash the PCM the first time. They are assembled with no memory and once completed they are flashed and tested. Once passed they are completely dipped in an epoxy to protect the board for the environment. After that the port is left accessible make the PCM upgrade-able through firmware flashes. Since the factory can't know that a firmware flash is going to happen it's protected from corrosion. My '97 mustang has the same connection and it's never been flashed but it can be if Ford decided that it needed to be done.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 3 Old 08-20-2014, 07:55 AM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Hmm interesting, i suppoose if anyone would know it was you
Just spitballing but wouldnt they just flash the PCM through the OBD port. I know that OBD II was in its infancy in 1994 but i would think that that ability was there right?
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
