Turbo-back Exhaust for Manual 4x4 - Ford Powerstroke Diesel Forum
post #1 of 17 Old 08-19-2014, 01:54 PM Thread Starter
Question Turbo-back Exhaust for Manual 4x4
So I got excited when I saw a vendor had the stainless steel turbo-back exhaust system (MBRP) I'd been eyeing on sale. But then I noticed in the product description that it was only available for automatic transmissions. A call to both the vendor and to MBRP confirmed that MBRP in fact did not manufacture a turbo-back system for a 1997 manual 4x4 F250! I did a bit of forum searching & discovered that aftermarket downpipes are not easy to install on these trucks. So much for a DIY installation I guess. This leads me to a couple of questions:
Does any company manufacture a quality stainless steel turbo-back exhaust system that will fit a 1997 manual 4x4 F250?
For those of you with experience installing a turbo-back system on a 1997 manual 4x4, what exactly are the challenges that DIY installer would face?
7.3dieselMike is offline
post #2 of 17 Old 08-19-2014, 02:24 PM
Quoted: 23 Post(s)
i can't see what the difference would be. I have a 97 4x4 manual and my 3' down pipe and "race pipe" went in relatively easily...
I used diamond eye parts though.
Syndicated_cdn is offline
post #3 of 17 Old 08-19-2014, 02:49 PM
Quoted: 60 Post(s)
Evidently it's a tighter fit with a manual. Any research on the various forums will indicate that the Diamond Eye fits better than the MBRP ("Mounts, but Really Poorly..."), since it's a two-piece and can be adjusted for minor cab-frame-powertrain space differences. Just speculating, but I'll bet the people with fitment issues are also those with old, compressed cab mounts, and a fresh set of cab mounts would add some wiggle room.
I'm guessing that for all these reasons, MBRP is covering its hiney by "qualifying" it for automatic trucks only.
madpogue is offline
post #4 of 17 Old 08-19-2014, 03:48 PM
the baconator
terryknight's Avatar
Quoted: 153 Post(s)
the manual bell housing sticks out rubs the DP. i have an MBRP and it sucks, had to bend it quite a bit to get it to fit. I will us diamond eye net time
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #5 of 17 Old 08-20-2014, 07:43 AM
dr.deere's Avatar
Quoted: 19 Post(s)
I have a diamond in my 97 with a manual the normal massaging if the firewall and down pipe clears great. I wasn't able to be around when the rest of the exhaust went in but my brother and a friend said it was easy to put the whole thing. I have 3 in dp and 4 in the rest of the way
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #6 of 17 Old 08-21-2014, 01:22 PM Thread Starter
So the verdict for a downpipe on a manual is Diamond Eye?
What are the advantages of having a 4" or 5" exhaust tube after the 3" downpipe?
post #7 of 17 Old 08-21-2014, 01:32 PM
the baconator
Quoted: 153 Post(s)
none. personal preference and sound
post #8 of 17 Old 08-21-2014, 01:50 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
They both will fit, but as terry said the hell is slightly larger so a little more firewall persuasion is required, I like the 5" system better Kause it sounds awesome, it's slightly deeper then the 4" kit, but no real differences other then that
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #9 of 17 Old 08-21-2014, 06:51 PM
dr.deere's Avatar
Quoted: 19 Post(s)
I like my 4in sounds way better than the hack job that's under my 94. I've never got to hear a 5 before though
dr.deere is offline
The Following User Says Thank You to dr.deere For This Useful Post:
Myjack (09-05-2014)
post #10 of 17 Old 09-05-2014, 06:51 AM
Is there somewhere that shows where and how much the firewall needs to be adjusted to clear the 3" Diamond Eye Downpipe?
I just ordered one and planning an engine swap, so it should be easier to modify the firewall with no motor.
Thanks!
Myjack is offline
Tags
4x4 , exhaust , manual , turbo-back
