In need of gauges - Ford Powerstroke Diesel Forum
post #1 of 21 Old 08-17-2014, 08:43 PM Thread Starter
bdemutis's Avatar
Quoted: 9 Post(s)
In need of gauges
So I'm almost ready to get my truck on the road I need gauges. I need a water temp and oil pressure gauge because mine do not work. I really would like to get 3 gauges oil pressure water temp and boost. I want to know what gauge company should I go with should I get a gauge kit? I was thinking maybe glowshift gauges I put together a kit and it came to around $168 with everything. What are other good inexpensive companies to look at since I really do need gauges.
bdemutis is offline
post #2 of 21 Old 08-17-2014, 09:20 PM
over thinking everything
fordmandan87's Avatar
Quoted: 3 Post(s)
Autometer has good gauges. I would recommend trans temp egt (pyro) and boost in a triple a pillar pod
97 F-250 CCSB 4x4 7.3 E40D 305,000 miles 285/75/16 Cooper Discoverer at3s' diy 6637 intake diamond eye 4in stainless turbo back straight pipe auto meter pyro, trans temp and boost gages on triple a pillar pod baby swamps and php hydra chip - paid off 335hp 704tq
currently getting 12.5 mpg hwy
Originally Posted by 351fifty View Post
Don't mind JJ, he lives near Santa, but uses a powerstroke instead of reindeer
fordmandan87 is offline
post #3 of 21 Old 08-17-2014, 09:48 PM
sbluke55's Avatar
Quoted: 528 Post(s)
Garage
I have isspro and love them. Autometer are good too. Like said above get trans, egt, and boost. You should be able to repair your sensors cheaper than buying aftermarket ones.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #4 of 21 Old 08-17-2014, 10:47 PM
john galt's Avatar
Quoted: 1189 Post(s)
MOST of the people I have talked to running glowshift have had good luck with them. but not all.
as stated above replacing your sensors is probably cheaper and easier than going all aftermarket.
I am getting a set of glowshifts because they have a perfect match to my dash gauges that really are totally worthless but...
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, sinister coolant filter(this is the ONLY pos sinister product that will ever be on my truck), riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #5 of 21 Old 08-18-2014, 01:13 AM
897.3alltheway!'s Avatar
Quoted: 11 Post(s)
yea OP dont go with glowsh!t , the percent of people who have gad BAD luck with them out weigh the people who have had good luck by a long shot , if you truck has a manual trans you dont need a trans gauge , you should buy a quad gauge pod and get isspro gauges
-Jeremy
Got A Few Rides...
897.3alltheway! is offline
post #6 of 21 Old 08-18-2014, 06:47 AM
dr.deere's Avatar
Quoted: 19 Post(s)
I run auto meter gauges. I had a bad experience with isspros before.
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is online now
post #7 of 21 Old 08-18-2014, 06:50 AM
dannanw's Avatar
Quoted: 64 Post(s)
Garage
here's one
Isspro gauges
I got mine here, good packages...
Performance Gauges for Diesel Trucks from ISSPRO and Autometer
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #8 of 21 Old 08-18-2014, 08:18 PM Thread Starter
bdemutis's Avatar
Quoted: 9 Post(s)
It's a manual don't have a trans cooler so really no need is there?
bdemutis is offline
post #9 of 21 Old 08-18-2014, 08:20 PM Thread Starter
bdemutis's Avatar
Quoted: 9 Post(s)
I already replaced my sensor on my oil pressure it wont work and auto meter are to much for me $80 a gauge on a truck that I paid $1100 for and only put a grand into.
bdemutis is offline
post #10 of 21 Old 08-18-2014, 08:21 PM Thread Starter
bdemutis's Avatar
Quoted: 9 Post(s)
I need something that wont break the bank I do have a manual trans I really need oil pressure and coolant temp because I replaced the sensors and the gauges still don't work.
bdemutis is offline
