Clutch noises louder and help needed - Ford Powerstroke Diesel Forum
post #1 of 39 Old 08-17-2014, 05:44 PM Thread Starter
pk64f100's Avatar
I dont know what to do, do I need to replace my clutch, it is really getting very loud and chattering more and more everyday. It seems to operate OK but I am very worried because of how loud it is becoming. If the clutch is working OK but just making noise is advisable to replace everything or just replace what is needed. I would have to take to shop, I have am not able to do this with my health right now. The previous owner said he put in a Southbend single disc but left stock flywheel I don't know what to believe with this guy so I need help.
I am looking at this kit fro Pheonix Friction, anyone use them and are they reputable?
Part / description:
07-501CK Solid Flywheel Conversion Clutch Kit: Ford 7.3L Diesel F250 F350 F450 Pickup - 13 in.
pk64f100 is offline
post #2 of 39 Old 08-18-2014, 06:51 AM
dr.deere's Avatar
Quoted: 19 Post(s)
If he left the stock flywheel it's dual mass and that is probably
Where all the noise is coming from. I've heard that the dual mass and single mass flywheels have different clutch bolt patterns. But not sure. I have had good luck with luk single mass conversions before as well.
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #3 of 39 Old 08-18-2014, 09:00 AM
Are you certain that it is either the flywheel or clutch making the noise. There's a lot going on down there, so I would want to make sure you're dealing with the right problem. Is there noise throughout driving, or only during certain times? Does the noise stop when you depress the clutch...or does it get worse??
1996 F350 4x4 CCLB E4OD
Stage 1's, Tony Wildman Tunes, 6637 Intake, 5" Stainless Exhaust, Bilstein 5100's, FPR Spring Mod, Dark Blue CPS, Pillar Gauges (trans temp, pyro, boost), 6.0 Fan Mod, Tru-Cool Max Trans Cooler (and SD Cooler Lines), HPX Crossover, Alum Radiator, 203 Deg DieselSite Thermostat, '08 SD Alum Finned Rear Diff. Cover, PMF RSK (w/ V-Codes)
majorgator is offline
The Following User Says Thank You to majorgator For This Useful Post:
pk64f100 (08-18-2014)
post #4 of 39 Old 08-18-2014, 09:47 AM
Quoted: 44 Post(s)
Remove the inspection plate and try to rotate the flywheel by hand. If it turns any significant amount, that means it's indeed the OEM dual-mass (aka "dumb-mass") flywheel, and the springs and other bits holding the two sections together are weak. The dual-mass is a ticking time bomb; if it completely lets go while you're underway, it can grenade the tranny case.
Do you hear an extra "clack" or "clunk" when you shut down the engine? That's also an indicator of the dual-mass flywheel near failure.
Not sure about bolt patterns, but the flywheel and clutch should always be matched, or at least known to be compatible with one another. Moreover, what the PO did, installing a new clutch and retaining the OEM DM flywheel (even if they're compatible), is about the stupidest way imaginable to service that part of the truck. Once you have the tranny out and are doing the clutch kit, it's a fool's errand not to swap to a single-mass.
Do you have any idea how many miles ago the PO had the Southbend installed?
madpogue is offline
The Following 2 Users Say Thank You to madpogue For This Useful Post:
pk64f100 (08-18-2014), spf808 (12-02-2014)
post #5 of 39 Old 08-18-2014, 02:51 PM Thread Starter
pk64f100's Avatar
Noise goes away when
The noise goes away when I depress clutch in but it is noisy when in nuetral and it seems to be louder when I am taking off but since there is no muffler and the engine is a little noisy it hard to tell once underway at high speeds. It seems to operate OK every once in a while it is a little hard getting it into reverse and 2nd gear downshifting is hard unless going slowly and double clutching it. Thanks for your help
pk64f100 is offline
post #6 of 39 Old 08-18-2014, 02:54 PM
dannanw's Avatar
Quoted: 54 Post(s)
Garage
Time for a clutch and flywheel like others said, and new throwout bearing.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #7 of 39 Old 08-18-2014, 03:04 PM Thread Starter
pk64f100's Avatar
Previuos owner issues
Yes, the PO was a real dumb-*** the work he did not do and the work he did do was really crappy come to find out as I get into more and more of the truck. I have no idea why he would have left the OE flywheel in place, I sure would not have and I really believe that he had no idea what he was doing or he had someone working on his truck who had no idea what he was doing which is surprising since he worked for a local Dodge / Ford dealership as a tire changer, parts swapper and shop work, he sure is no mechanic. I have to fix the mess he made out of so many easy repairs (wiring, ignition, exhaust, exhaust and now this) its not funny. I do believe it is the clutch since the way it goes away when I depress clutch pedal it goes away.
I am on vacation and I am hoping to take it to a local mechanic near Bethany Beach Delaware where we are this week who can possibly help me. I have had 4 spinal surgeries and my days of getting under trucks removing trans, clutches and heavy work are over unless my son is handy to help me but he is off at college now.
pk64f100 is offline
post #8 of 39 Old 08-18-2014, 03:05 PM
sbluke55's Avatar
Quoted: 502 Post(s)
Garage
Sounds like it's not fully disengaging and the throw out bearing is riding against the clutch fingers to me. Causing the bearing to start to fail and cause noise.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
The Following User Says Thank You to sbluke55 For This Useful Post:
post #9 of 39 Old 08-18-2014, 03:17 PM
Quoted: 22 Post(s)
make sure the pilot bearing is changed as well. it is often overlooked on DIY clutch replacements.
hopefully the input shaft bearing is ok on the trans, noisy in neutral with clutch engaged (pedal out) is a possible symptom, hopefully you don't need a rebuild
Syndicated_cdn is offline
The Following User Says Thank You to Syndicated_cdn For This Useful Post:
post #10 of 39 Old 08-18-2014, 04:16 PM Thread Starter
pk64f100's Avatar
Input shaft and bearing
If it is input shaft bearing will the Kevlar bushing that south bend has available which I read will help even if the Input shaft has been scared and replaces the bearing, does anyone know anything about this and if it would in fact help? I am far from a mechanic, does it sound like I need a new clutch and and flywheel & trans rebuild? Would it be not smart of me to have the clutch, TO bearing and main seal replaced without rebuilding trans? I really can not afford a trans or for that matter a clutch and need to try to repair what is most needed at this time, for lack of a better word I am hurtin' for $$$ (college, camp and grandchildren the list goes on and on...)! Any help would be greatly appreciated and if anyone knows a good reasonable mechanic in Maryland / Delaware area let me know. Thanks!
pk64f100 is offline
