E4od to transfer case question - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-17-2014, 05:24 AM Thread Starter
sandrock1's Avatar
When putting the transfer case onto a new transmission do I need to do anything else other than put a new gasket on? And do I put something onto the gasket or just put it on dry?
sandrock1 is offline
post #2 of 4 Old 08-17-2014, 06:37 AM
Quoted: 88 Post(s)
Feedback Score: 4 reviews
No you don't need to do anything else and the gasket can go in dry. Did you replace the trans output shaft and transfer case input shaft seals?
Jack
97 F250 Xlt, built E4od, D60 swap, Baby swamps, tunes by Dp
1.0 housing w/ wwII, 203* t-stat, diy 6637, 4" exhaust
Diy intercooled, 6.0 fan, Diy 140v Idm, Isspro Ev gauges
On board air, 38 Gal rear tank, E-fuel, 6" lift on 35's
322000 miles
1Dieselman is offline
post #3 of 4 Old 08-17-2014, 07:07 AM Thread Starter
sandrock1's Avatar
I didn't actually do anything yet but I will be soon. I just wanted to make sure I knew what I was getting into ahead of time. Should I replace seals though on the transfer case. If I remember correctly one is leaking but not badly. I forget which one it is.
post #4 of 4 Old 08-17-2014, 09:27 AM
Quoted: 88 Post(s)
I sure would replace seals.
Jack
322000 miles
