rear license plate lights not working - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-16-2014, 05:10 PM Thread Starter
I have a quick question my rear license plate light arent working they used to then a few weeks later they stoped working. I bought new light assembly's still doesnt work i tested the wires im getting power idk what else to do if you have any suggestions it would be appreciated.
nova1972 is offline
post #2 of 9 Old 08-16-2014, 05:44 PM
Quoted: 9 Post(s)
If you have power, and a working light assembly, it's most likely a ground issue.
plumberluke is offline
post #3 of 9 Old 08-17-2014, 10:10 AM Thread Starter
how would i go about to fix that im not really familiar with electrical i know what a ground is but if you could give me some more info i would appreciate it.
nova1972 is offline
post #4 of 9 Old 08-17-2014, 12:15 PM
leojr's Avatar
Quoted: 4 Post(s)
Do you have one wire going to your light fixture or two?
If one wire then the fixture grounds through the case to the bumper. You will want to make sure where the fixture snaps into the bumper is not crusty and making good electrical contact.
If it is two wires to the fixture then you have a wire that is broken somewhere.
Humor me and check your fuse again, location #10, small panel by your left knee.
Maybe snap a pic from the back side so we can see what you are dealing with.
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
leojr is offline
post #5 of 9 Old 08-19-2014, 03:55 AM
pk64f100's Avatar
The wires should be over by the drivers side rear light and if I remember correctly one is brown and one is purple. As long as you have two wires coming out of new light then you can ground it to back of bumper and power should be hot you said. Also some have these tied into the trailer wiring, I mounted a new one and tied power to the factory hot wire at rear drivers side running / brake lights and grounded to back of bumper it works great.
pk64f100 is offline
post #6 of 9 Old 08-19-2014, 06:18 AM
pk64f100's Avatar
Clutch noise video
The noise is the same with truck in neutral and in gear running. I recorded the clutch depressed and other ways where you can hear the noise It is also very hard to get into reverse till truck is warm and downshifting into 2nd at high speeds. I could not figure out how to upload video but here is a youtube video of it. Thanks
http://youtu.be/c94DHTNH_vI
pk64f100 is offline
post #7 of 9 Old 08-19-2014, 06:22 AM
sbluke55's Avatar
Quoted: 570 Post(s)
Garage
https://www.youtube.com/channel/UCfx...are_video_user
Wrong thread man. Post it up in yours.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #8 of 9 Old 08-19-2014, 06:24 AM
pk64f100's Avatar
pk64f100 is offline
post #9 of 9 Old 08-19-2014, 06:53 AM
pk64f100's Avatar
My apoligies
Sorry, I messed up
pk64f100 is offline
