another no start please help! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-11-2014, 05:35 PM Thread Starter
Question another no start please help!
ok so no start about month and a half ago, turned out was lift pump in valley , replaced, and fired up and purred like a kitty. drove it for the month maybe a thousand miles tops. drove to work and when i went to leave crank crank no start. diagnosis so far
- fuel pressure round 50 when cranking
- ICP sees 120 to 160 PSI during cranking
- does not start when ICP is unplugged
- fuel bowl fills up when i empty
- no smoke out of tail pipe
-i assume injectors are not firing/ they all pass buzz test
-IPR duty cycle max 18% during cranking
- tried IDM still didnt start
- i have enough RPMs and its a new ford gray CPS
i am starting to think it is the IPR maybe stuck open but it is a 200$ sensor and really don't want to guess the truck has 298k miles and never skipped a beat i also got a ton of codes but the one that sticks out the most is the IPR circuit fault
i am using a snap on solus scanner BTW please help i don't want to just replace parts.
1997 F250 ,7.3, 4" exhaust, afe cold air, dp tunes, and 33s
viggy924 is offline
post #2 of 5 Old 08-11-2014, 07:25 PM
sbluke55's Avatar
Quoted: 590 Post(s)
Garage
What is your icp pressure when the connector is unplugged?
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #3 of 5 Old 08-11-2014, 07:36 PM
sbluke55's Avatar
Quoted: 590 Post(s)
Garage
Also check your ipr wiring harness for chaffing and broken insulation.
01 f-250, Standard
sbluke55 is offline
post #4 of 5 Old 08-12-2014, 08:33 AM Thread Starter
it was around 2400 and the wiring looks good
viggy924 is offline
post #5 of 5 Old 08-13-2014, 05:02 PM Thread Starter
Ok so I pulled ipr doesn't seem to be stuck but the magnet looks like crap I guess gonna throw a new one in and hope for the best
viggy924 is offline
