Front Diff Chatter and Axle Swap - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-11-2014, 08:45 AM Thread Starter
I am going to try to keep this as short as I can, which means I may leave out info so let me know if you need more.
The problem is when I shift into 4 I get chatter from my front end which I assume is my leaky front diff. I have a long driveway to plow all winter so I need to fix this now before the snow starts.
My 1st Question is this:
  • My truck is a 96 250 7.3 with a C5 axle code 6250 (weight rating) - Ford full float Sterling 10.25 4.10 (single rear wheel) with limed slip diff.
  • I Have a donor truck that is a 94 5.8l gaser with a 35 axle code 6250 (weight rating) - Ford full float Sterling 10.25 4.10 (single rear wheel)
Can I swap them out? Does the 35's open rear axle apply to the front axle as well? If yes, would I notice a difference in 4WD?
My Second question is if any of you know of a place to buy a complete front end rebuild kit that contains everything from the tie rod ends, to bushings, to ball bearings, etc. I know this has been talked about before, but all of the links I find are now dead. If there is not a kit, does anyone have a list of the parts I should track down. I figure if I am going to have the axle off I should do this (it needs it).
Thanks,
Also let me know if I should have posted this elsewhere
old96stroker is offline
post #2 of 7 Old 08-11-2014, 01:24 PM
dr.deere's Avatar
Quoted: 19 Post(s)
You would be money ahead to put a d60 straight axle in it. 250s are twin I beam. Cost the same to do all the tie rod ends ball joints etc. but the 60 will last longer in between needing it all done. If you could find a donor truck. F350. To get all the parts from with 4:10 gears it's a day swap. I would go through it before you put the 60 in though.
Sent from AutoGuide.com App
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #3 of 7 Old 08-11-2014, 05:30 PM Thread Starter
Thanks for responding.
From what I've seen around, that would cost me $150-300 to pick up a D60, it isn't really in the budget. That said, are there other benefits other than longevity? I haven't really read up on it because I never planned to pull my axle.
post #4 of 7 Old 08-11-2014, 05:56 PM
elrojo63's Avatar
D60s are just a stronger axle that can take the abuse of the motor's weight along with plowing and off-roading. If you pull and rebuild the stock axle now you'll be farther behind when you end up doing an axle swap later anyways if you're going to be abusing it a lot
1997 PSD Crew Cab Shorty Centurion Flatbed 234k D60 Swap
Leather Interior, built in radar detector, 5 inch dozer stack, DIY exhaust brake/TC lockup
1997 F-250 PSD ZF5 4x4 RCLB 362k SOLD
1953 Clark Carloader Forklift
1996 Subaru Legacy Wagon
2001 Big-Tex 16' Landscape Trailer
2006 Suzuki King Quad 750 27 inch ITP Mudlites
elrojo63 is offline
post #5 of 7 Old 08-11-2014, 07:17 PM
dr.deere's Avatar
Quoted: 19 Post(s)
If you can get one for 300 it less. You are very lucky and should jump on it. I paid 500 for mine and them had to rebuild and re gear. I've heard if others paying up near 1k for an axle they had to go through. I think the 60 handles better as well as taking the abuse better and the weight of diesel. I totally understand the budget issues. But as a guy who has wasted plenty of money because it wasn't in the budget at the time and regretted it later. I would def do some research and put some serious consideration into the idea.
dr.deere is offline
post #6 of 7 Old 08-12-2014, 05:00 PM Thread Starter
I agree, and your right, I just did a quick search and they range from 500-800. Found one about 90 Minutes from me for $200, but I have to do the front shackles, shocks, and all the steering from the tie rod on out. However, the one upside is, if not for a broken front diff I would never have considered pulling the front axle, but now that I will have done it once I will be a lot more prone to do it again. The donor truck is what I have, but after parting and scrapping the rest of the truck, I want to get another parts truck. Maybe I will be lucky and the next one will be a powerstroke and a 350!
I wish I could do it now, but I am planning on having this truck for a looooooong time. Ask me in 20 years, I plan to still have it.
post #7 of 7 Old 08-12-2014, 05:09 PM
dr.deere's Avatar
Quoted: 19 Post(s)
I hear ya on keeping it for a long time. I have more invested in both of mine than they are worth. I will have them for ever. Maybe in twenty years I can have both to where I want them to be.
dr.deere is offline
Tags
axle swap , front end noise
