CNG system - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-08-2014, 07:39 AM Thread Starter
CNG system
I'm considering buying this kit for my truck. It looks promising. Anyone here use this product?
cngedge
Mike
97' F250HD XLT 4x4 | NAPA 6637 | TS Chip | Straight Pipe | CCV Mod | LED lighting | Coolant Filter | 203° Thermostat|
mikeallenbrown is offline
post #2 of 9 Old 08-08-2014, 07:47 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
The benifit seems great, but diesel is hard enough to find on some stretches of interstate
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 9 Old 08-08-2014, 08:04 AM Thread Starter
The beauty of this system is that you can switch between diesel only or diesel/CNG combination. This isn't a complete switch over to CNG. It's a dual fuel setup. Running out of CNG wouldn't be an issue as you'd just continue on running on diesel fuel.
Mike
post #4 of 9 Old 08-08-2014, 08:14 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
But how long of running on Cng would it take to return your investment? Like I said it sounds great, but I'm not sure it would sustain itself to return my investment especially after I would have added other performance parts, it would be good for road trips or the commute however, what kind of economy would it behold? The cost per gallon is nice
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #5 of 9 Old 08-08-2014, 08:39 AM Thread Starter
The site and their youtube videos say 40-60 mpg depending driving conditions.
Mike
post #6 of 9 Old 08-08-2014, 08:51 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Sorry I missed that part
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #7 of 9 Old 08-08-2014, 08:54 AM
strokersixo's Avatar
Quoted: 33 Post(s)
I'm getting 14 mpg with straight diesel, but hmm. If I can get even close to 30 I'd be a happy camper, don't know if this can be adapted for a 6.0l. All their Vids show older makes and models.
Sent from tapatalk PRO ........ I WISH
--MAX--
strokersixo is offline
post #8 of 9 Old 08-08-2014, 12:25 PM
Neat idea, but how does it work when hauling a load? Does it say on there how much CNG you actually burn per mile? I didn't see where they said it...maybe I missed it?? Looks like they had a massively large tank in the bed of the truck. Who cares if you're getting 60 MPG with diesel if you're only getting 2 MPG on the CNG.
And FWIW, the closest CNG station to me (according to the map they link to) is a little over an hour away from me, and the cost per gallon is listed at $2.35. I just paid $3.71 for diesel today...
1996 F350 4x4 CCLB E4OD
Stage 1's, Tony Wildman Tunes, 6637 Intake, 5" Stainless Exhaust, Bilstein 5100's, FPR Spring Mod, Dark Blue CPS, Pillar Gauges (trans temp, pyro, boost), 6.0 Fan Mod, Tru-Cool Max Trans Cooler (and SD Cooler Lines), HPX Crossover, Alum Radiator, 203 Deg DieselSite Thermostat, '08 SD Alum Finned Rear Diff. Cover, PMF RSK (w/ V-Codes)
majorgator is offline
post #9 of 9 Old 08-08-2014, 08:43 PM
Quoted: 9 Post(s)
Sounds like a great idea but apparently the government has gotten their hands on the tax machine here in Colorado. There are 2 stations in Colorado Springs both on the military base one is priced at $2.99 and the other is $4.50. Diesel here is running at $3.79. The math doesn't seem to work out. Now I can see in the surrounding states the prices are below $2. The math doesn't seem to work out so well out here.
1997 Crew Cab Long Bed 4X4 (DRW Conversion) Auto. 280K miles
Stainless Irate Bellowed Up Pipes
Fresh Turbo with 1.0 Housing & Wicked Wheel II, 3" downpipe with 4" exhaust, Intercooled, 6.0 Fan, 39 gal rear fuel tank + 70 gal Transfer Flow in the bed, Hydroboost, Completely New Suspension (Springs, Shocks, Bushings),08 Rear Diff Cover, Baby Swamps, Hydra Chip with Swamps Tunes, and Swamps IDM, Dually Swap, Tru-Trac locker in the rear, Red Head Steering Box and Borgeson Steering Shaft
ChallengerRV is offline
