How the hell do you get the side rear window out of a Crew Cab?!?! - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-07-2014, 05:37 PM Thread Starter
I have the rear window completely free of everything in the door but it physically will not come out of the window hole. Is there something i'm missing here? I would greatly appreciate it if someone can help me out.
Quattro is offline
post #2 of 9 Old 08-07-2014, 09:12 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Are all the brackets in the door removed?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 9 Old 08-08-2014, 09:09 AM Thread Starter
Yes, everything is removed. The glass seems too big to be pulled out of the frame.
Quattro is offline
post #4 of 9 Old 08-09-2014, 07:46 AM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
The factory service manual has you remove he glass through the window opening. Cheers!
Patrick Feeley is offline
post #5 of 9 Old 08-09-2014, 07:56 AM
ZMANN's Avatar
Quoted: 1658 Post(s)
window opening ??
is that the technical term for the
window hole
We Miss you Ronnie
ZMANN is online now
post #6 of 9 Old 08-09-2014, 08:08 AM
Quoted: 15 Post(s)
Sorry for missing that. That is what the manual says. Definitely not going to fit through any of the openings in the lower section. I will assume you tried to rotate the glass and have the scrapers out? Cheers!
post #7 of 9 Old 08-09-2014, 08:20 AM
ZMANN's Avatar
i was bagging on you Patrick
I was getting a laugh out of the OP's term "Window Hole" struck my as funny
wish I could help the op he must be missing something but it went in through the window opening when it was installed it must come out the same it's not like a ship in a bottle where they build the outside around the part lol
We Miss you Ronnie
ZMANN is online now
post #8 of 9 Old 08-09-2014, 11:27 AM
You have to pull the U channel. There are also a couple bolts/nuts that hold the regulator straight. Then you rotate the window either forward or backwards. It comes out then. It's not real fun to pull. I would also recommend wrapping the glass inside and out with blue painters tape. Glass can get scratched.
Got4wd is offline
post #9 of 9 Old 08-09-2014, 04:34 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
^^ What he said, you have to rotate the glass. I forget if it is clockwise or counter. It has been too long
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
