Aftermarket Alcoa Dually Wheels (Non Ford) - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-06-2014, 08:42 PM Thread Starter
Quoted: 7 Post(s)
I found a set of Alcoa dually wheels on Craigs List for a good price but they came off of of Chevy 3500 Mid 90's model. The seller says that they are 6 X 6.5 bolt pattern and I am wondering if they will fit my truck. I am about ready to install of my dually conversion stuff. The Dually D60 Hubs and the freshly rebuilt 10.25 with a True-Track a real pretty set of wheels for a good price would really make me happy.
1997 Crew Cab Long Bed 4X4 (DRW Conversion) Auto. 280K miles
Stainless Irate Bellowed Up Pipes
Fresh Turbo with 1.0 Housing & Wicked Wheel II, 3" downpipe with 4" exhaust, Intercooled, 6.0 Fan, 39 gal rear fuel tank + 70 gal Transfer Flow in the bed, Hydroboost, Completely New Suspension (Springs, Shocks, Bushings),08 Rear Diff Cover, Baby Swamps, Hydra Chip with Swamps Tunes, and Swamps IDM, Dually Swap, Tru-Trac locker in the rear, Red Head Steering Box and Borgeson Steering Shaft
ChallengerRV is offline
post #2 of 5 Old 08-06-2014, 08:54 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Measure the hub circle, pretty sure the Chevy version is to small, dodge ones fit however
If they are stamped with a bow tie they will NOT work, alcoa made aluminum wheels for all 3 companies and stamped the manufacturer emblem on them as to where they went, but if they are straight aftermarket alcoa wheels they should fit fine,
Easiest thing for me is to take an extra hub/rotor with ya and just make sure it fits all the way in AND the bolt pattern is correct
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 5 Old 08-06-2014, 09:00 PM Thread Starter
Quoted: 7 Post(s)
They are stamped and stickered with the Alcoa logo with no oval or bow ties in sight. I do have a rear hub off of the axle so I could take it with me to look at them. Only problem is they are a little over 2 hours away. Would be nice to have the odds on my side before that long of a drive
post #4 of 5 Old 08-07-2014, 09:45 AM
Quoted: 43 Post(s)
Ummmmmm, those are 6-lug wheels.......
(Just sayin')
madpogue is online now
post #5 of 5 Old 08-07-2014, 09:53 AM Thread Starter
Quoted: 7 Post(s)
Good catch madpogue. I did a typeo . They are 8 lug 8 X 6.5.
