question with trailer brake control - Ford Powerstroke Diesel Forum
post #1 of 7 Old 08-05-2014, 12:08 PM Thread Starter
Nitro41's Avatar
I have a 97 f250 xl truck. It has a hitch and a 4 pin. What do I need to setup a 7 pin and trailer brake controller? Is there factory wiring I can plug into or will I need to run all of my own wires?
Any help is appreciated
97 Single Cab F250 4x4 5 speed
Swapped D-60
Locked front and rear
160 sticks
Wildman Tunes
Hood Stack
OFE clutch
T500 HPOP
Linex rockers
35" MTR Kevlars
and a bunch more...
Nitro41 is offline
post #2 of 7 Old 08-05-2014, 12:19 PM Thread Starter
Nitro41's Avatar
Theres 1 round plug that not currentlybeing used at the back of the truck where the connector is for the 4 pin, also, theres 3 open connectors to the left of the obd2 port in the cab
Swapped D-60
160 sticks
Wildman Tunes
Hood Stack
OFE clutch
T500 HPOP
Linex rockers
35" MTR Kevlars
and a bunch more...
Nitro41 is offline
post #3 of 7 Old 08-05-2014, 03:53 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
behind the power distribution box under the hood there should be two relays, these are part of the trailer package. you can see them in teh botttom right conrer.
if you have them that's great if not, go find a truck as a JY that does, take them and the 7 pin trailer connector from the rear. plug the seven pin in the rear using the 4 pin (left, right, tail, ground) that your current lights are plugged into and the other unused three pin (positive, brakes, backup lights). you can kinda see them in the bottom left of this pic
i don't know where plug under the dash is but it is 5 pin and should be under the little cubbyhole somewhere, i believe it is gray
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 7 Old 08-05-2014, 09:18 PM Thread Starter
Nitro41's Avatar
Are those 2 relays on a seperate harness that goes into the cab?
Swapped D-60
160 sticks
Wildman Tunes
Hood Stack
OFE clutch
T500 HPOP
Linex rockers
35" MTR Kevlars
and a bunch more...
Nitro41 is offline
post #5 of 7 Old 08-06-2014, 03:00 AM
the baconator
Quoted: 146 Post(s)
they have separate wires that plug in right under the brake booster. the wiring is already there, just not used
post #6 of 7 Old 08-06-2014, 03:39 AM
dr.deere's Avatar
Quoted: 19 Post(s)
I found the plug under the dash in my 97 right in the middle of the Trans tunnel in the harness that runs under the dash. It was next to the connector for the AIC.
Sent from AutoGuide.com App
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #7 of 7 Old 08-06-2014, 03:40 AM
dr.deere's Avatar
Quoted: 19 Post(s)
One thing I did notice though when I hooked mine up through the factory wiring. If I'm backing up with the hazards on it sets my trailer brakes.
dr.deere is offline
