Fuel Pump Recommendation - Ford Powerstroke Diesel Forum
post #1 of 11 Old 08-05-2014, 04:43 AM Thread Starter
I've got so many parts on order, and I'm planning a few weeks of on/off working on the truck. One of the first things I'm doing is replacing the fuel tanks. This got me thinking about replacing the fuel pump too. I don't know if its necessary, but hey, why not?
Now...I'm not interested in converting to e-fuel...so let's leave that alone
Before I begin my internet scouring for a new fuel pump, does anyone have a good recommendation for a quality pump that will be dependable for many miles?
1996 F350 4x4 CCLB E4OD
Stage 1's, Tony Wildman Tunes, 6637 Intake, 5" Stainless Exhaust, Bilstein 5100's, FPR Spring Mod, Dark Blue CPS, Pillar Gauges (trans temp, pyro, boost), 6.0 Fan Mod, Tru-Cool Max Trans Cooler (and SD Cooler Lines), HPX Crossover, Alum Radiator, 203 Deg DieselSite Thermostat, '08 SD Alum Finned Rear Diff. Cover, PMF RSK (w/ V-Codes)
majorgator is offline
post #2 of 11 Old 08-07-2014, 06:53 PM
PowerstrokinIt F250's Avatar
You do not have a fuel pump in your tank, you have mechanical lift pump in your engine valley, underneath your turbo. If your looking to upgrade you will want to go with an electronic fuel system.
[IMG]http://i59.tinypic.com/33l06ll.jpg
1995 f350 7.3 4x4 auto 4door long bed 160,000 miles BONE STOCK for now. Cleanest truck in PA
1998 Mitsubishi Eclipse GSX 9.9@ 152mph
2003 Honda Civic daily driver
PowerstrokinIt F250 is offline
post #3 of 11 Old 08-08-2014, 02:58 AM Thread Starter
Yes, I know the fuel pump is not in the tank(s). The point is that I'm parking the truck for a few weeks to install a variety of things, some of which are under the hood. I'm not interested in an upgrade to the fuel system, but rather just considered replacing the pump since I know it's a common failure part. It also gives me an excuse to remove the turbo and install up-pipes.
post #4 of 11 Old 08-08-2014, 04:25 AM
Quoted: 22 Post(s)
I bought a Carter pump off of rock auto, i think it was $130 w/shipping. Working well so far!
Syndicated_cdn is offline
post #5 of 11 Old 08-08-2014, 04:42 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
The idea of not upgrading to e-fuel is absurd. mechanical pump even new is prone to failure and that's why we remove it and install an electric fuel system. Especially with your stage 1st you want that mechanical pump gone
What's your reason for not wanting e-fuel
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #6 of 11 Old 08-08-2014, 07:56 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
I wouldnt say its absurd, but its one of those things that its just plain good for the truck. Im so glad im rid of that huge ungodly fuel bowl and mech fuel pump. But e-fuel wasnt a decision made lightly since im not one for making big power mine was because the time was right due to a series of unfortunate events. Now having the stage ones will definitely beg for a better fuel system.
OP i know you dont want to but its your only way to upgrade the fuel system. Any replacement pump wont be any better(unless obviously its a bad pump now). But if your dead set on replacement, think about this, how long has your stock pump held up?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #7 of 11 Old 08-08-2014, 12:02 PM Thread Starter
Let me rephrase:
I am not interested in converting to e-fuel at this time. I've just poured out over $1K in various other upgrades that are more important to me right now than e-fuel. I was angling toward replacing the pump only because I take the truck on long trips (often hauling), and I simply like the insurance of having a new one. However, if it aint broke, don't fix it, I suppose. At some point over the next year or so, I may start gathering the parts for e-fuel. In the mean time, I've purchased the fuel line check valve delete fittings from Riff-Raff Diesel to help improve flow.
post #8 of 11 Old 08-08-2014, 01:00 PM
Phillipjon's Avatar
Quoted: 78 Post(s)
Where do those fittings go?
1996 F350 4X4 CCLB SRW
Full Force Stage 1.5-Swamps IDM-Efuel-Bosch 17* HPOP-Melling LPOP-Intercooled-Deleted pedestal-Stancor glow plug relay-1.0 housing-Isspro EV2's-Sky RSK-SD front and rear springs-Tru cool tranny cooler-Built Tranny-CCV mod-6 position chip running TW tunes-6637-3" down pipe to 4" straight pipe-Grab handle mod-Dual lighted visors-3.73 Gears-Warn hubs-SD aluminum rear diff cover-Dual front shocks-295/75/16 Toyo Open Country AT2's
Phillipjon is offline
post #9 of 11 Old 08-08-2014, 02:29 PM
the baconator
terryknight's Avatar
Quoted: 150 Post(s)
a fuel pressure gauge would serve you better then. when the pressure starts dropping then you can replace the pump
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #10 of 11 Old 08-08-2014, 05:14 PM
dirtcrew51m's Avatar
Quoted: 6 Post(s)
I like being absurd. I will take mechanical over electric any day. I sell alot of electric pumps that failed under 100,000 miles, both diesel and gas. The Ford and Dodge pumps are pretty popular. I have only sold a couple of 7.3 mech pumps and one was me, I just replaced mine at 170,000 just to do it, probably would have went over 200,000.
dirtcrew51m is offline
