'96 Powerstroke-"The Great Repair" Fixing It To Haul Reliably - Ford Powerstroke Diesel Forum
post #1 of 18 Old 08-04-2014, 03:56 PM Thread Starter
early1999powerstroke's Avatar
Smile '96 Powerstroke-"The Great Repair" Fixing It To Haul Reliably
Hello Everybody!
I recently purchased a 1996 F350 CCLB with a 7.3 and a 5 speed manual. It has 234,000 miles and was pretty much stock when purchased.
I decided to purchase this truck because:
A. I really like the OBS crew cab for family trips.
B. I like the 5 speed.
C. It has a 4:10 gear ratio which is great for towing.
D. I think the 7.3 Powerstroke is a great motor.
Things I have done to it so far.
1. Diamond Eye 4" Exhaust (3.5" Down Pipe)
2. 6637 Intake with Riff Raff Sleeve
3. AFE Rear Differential Cover with 75w-140 Synthetic Fluid Change
4. New Ball Joints, Front Wheel Bearings, Front Axle Seals, Front Disc Brakes, and Front Axle Fluid Change
5. New Coolant Cap
6. New Oil Fill Cap
7. New Injector O-Rings
8. New UVCH's
9. New Glow Plugs
10. New CPS
11. Unplugged EBPV
12. Oil Change, Fuel Filter Change, and Coolant Additive
13. CCV Mod
14. Riff Raff Intake and Plenum Boots
15. New ICP Sensor
Problems Remaining:
1. Leaking Up Pipes
2. Slow Turbo Spool (Doesn't come on till 1900 rpms)
3. Cranks slow when starting
4. Idles a little rough when at operating temp
5. Needs Clutch Replacement
6. Steering is sloppy
7. Smokes bluish white smoke when cold started. Smokes a little black smoke at WOT when hot.
8. Blow by amount seems normal for an engine of this vintage.
So...I've got a bit of work to complete on it before I haul cows this winter. I'm planning to fix most of these issues in the next 3-6 months. Here's what I've ordered in to prepare for the "GREAT REPAIR" as I've labeled it.
1. South Bend Clutch Kit. (350 hp capable...single disc)
2. Fast Spool Turbo from Ron Holland. (1.0 A/R exhaust housing)
3. EBPV Delete Outlet and Pedestal
4. New Stock Fuel Pump
5. High Pressure Oil Rail Cross Over Pipe
6. New Fuel and HPO Seals, O-Rings, and Sleeves
7. New Melling LPOP
Other things I hope to order for this repair segment:
1. Riff Raff Bellowed Up Pipes (They're out of stock for a couple of weeks)
2. Redhead steering gear box
3. Borgeson U-joint Steering shaft
4. A good set of shocks
Other things for next repair segment...(When I get some more money.)
5. MAYBE a set of stock injectors as I'm fairly certain that these have a large amount of wear with 234,000 miles.
6. MAYBE a 17 HPOP...gotta check pressures and duty cycle
7. MAYBE a good quality starter.
So, anyway, there's a description of what I'm doing. Please feel free to offer any suggestions or thoughts. I would appreciate any advice you might have as I have a fair amount of experience with these trucks but I know a lot of you have much more experience/knowledge.
Also, I have a couple of questions:
1. Should I replace the rear main seal?
I have read a lot of articles that say, "Don't Touch It!!!!" BUT.........it seems kind of foolish to be right there/ have access to it/ not replace it. It's not leaking to my knowledge at this time but it does have 234,000 miles on it.
2. Should I replace any of the seals on the ZF5/Transfer case while I have them out?
I think there is a little seepage of Transmission fluid from somewhere but nothing major.
3. Should I replace the O-Rings on the rear fuel rail plugs and HPO rail plugs while I have access to them with the tranny out?
4. Should I replace the water pump as a preventative measure while I'm changing the LPOP? It's the stock one from the factory.
5. Should I replace the wear ring on the damper when I am installing the LPOP? It's not leaking at this time.
I will probably have a few more questions as I work my way through this. Thanks in advance for your comments. I appreciate all the contributors on this forum.
Kind Regards,
Josiah
Happy to have a good, dependable truck!
early1999powerstroke is offline
post #2 of 18 Old 08-04-2014, 04:12 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
if it were me i wouldn't replace anything that didn't need it. do the clutch and the up pipes first. you may feel you do not need a 1.0 housing at that point. i would skip the HPX line, i feel it's one more thing to leak. check your oil pressure with a gauge, i have replaced the plug in the HPO reservoir with one from Napa. my stock pump with 277K+ miles is still fine. if you replace the injectors get bigger one (my thinking anyway). the water pump will mostly likely start to weep before it fails. replace it at that point. if you replace the LPOP or front seal you will need to replace the wear ring.
how is the GPR? that may have something to do with the smoke when cold.
invest in the FORD sealant, it's expensive but it works really well.
i also wouldn't put a stock fuel pump in i would swap to e fuel. really cleans up the engine bay.
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
The Following User Says Thank You to terryknight For This Useful Post:
early1999powerstroke (08-04-2014)
post #3 of 18 Old 08-04-2014, 04:51 PM Thread Starter
Thumbs up
Thanks for the reply terryknight.
I guess my thought process is that I don't want to have to tear into it more than I have to in the immediate future. Thus, the preventative replacements. I guess it also opens me up to possible problems if one of the replacements fail from one cause or another.
The GPR is new (Forgot to mention). When I replaced that along with the GP's it helped it start much better. The smoke on start up seems more like worn injectors. When I replaced the injector o-rings, that helped a little as a couple of them were leaking.
I have the HPX line on my Early 99 7.3 and it seemed to smooth out the idle and ICP readings just a little. I do agree with you though that it does give me more spots to have leaks.
I would love to go with E-fuel and maybe will at a later date but for now I just want to get the truck running as good as it can in semi-stock form. You are absolutely correct though that the engine valley is WAY over-crowded with the stock fuel system.
I think you are probably correct that the stock turbo would be much more impressive with intact up-pipes. However, I already have the replacement turbo so I will probably try it out. Also, the compressor wheel has a little wear to it on the original turbo so I was going to have to work on it anyway. No slop or bearing play though in the original turbo. I'll keep it around to tinker with.
Okay, I'll plan to replace the wear ring on the damper and buy the Ford sealant.
I'll also check the ICP with AE when I get a chance.
Thanks again for your thoughts and comments!
post #4 of 18 Old 08-04-2014, 05:16 PM Thread Starter
First Time Uploading Pics
Trying to get the size right so bear with me here.
ID:	320041   Click image for larger version
ID:	320049   Click image for larger version
post #5 of 18 Old 08-04-2014, 05:31 PM Thread Starter
More Pics
These pics should be bigger...
ID:	320065   Click image for larger version
ID:	320073   Click image for larger version
Name:	Truck Front 1.jpg
ID:	320081   Click image for larger version
Name:	Truck Front 2.jpg
ID:	320089   Click image for larger version
post #6 of 18 Old 08-04-2014, 06:49 PM
Consider the 6.0 fan swap. Really easy and moves more air.
Check the fuel tanks, as they probably leak.
1996 F350 4x4 CCLB E4OD
Stage 1's, Tony Wildman Tunes, 6637 Intake, 5" Stainless Exhaust, Bilstein 5100's, FPR Spring Mod, Dark Blue CPS, Pillar Gauges (trans temp, pyro, boost), 6.0 Fan Mod, Tru-Cool Max Trans Cooler (and SD Cooler Lines), HPX Crossover, Alum Radiator, 203 Deg DieselSite Thermostat, '08 SD Alum Finned Rear Diff. Cover, PMF RSK (w/ V-Codes)
majorgator is offline
The Following User Says Thank You to majorgator For This Useful Post:
post #7 of 18 Old 08-04-2014, 07:37 PM Thread Starter
Hey majorgator,
Do you use a stock 6.0 fan and the 7.3 fan clutch? Or is it something different? Is it fairly straight forward or do you have to mod the shroud or something? Couldn't find any articles on it but probably was just looking in the wrong place.
Where do the fuel tanks normally leak from?
Thanks,
Josiah
post #8 of 18 Old 08-04-2014, 07:59 PM Thread Starter
Okay, I found out the details on the 6.0 fan mod. Thanks for sending that my way.
post #9 of 18 Old 08-05-2014, 04:28 AM
OK, looks like you're good. Basically, remove the old metal fan from the clutch (after you remove the assembly from the water pump) and bolt on the new plastic fan. Its a straight-fit mod, no further changes required. For me, I could tell the difference in the sound as I rev'd up the engine. I just bought a plain 6.0 fan from Amazon, like $55 or so.
early1999powerstroke (08-05-2014)
post #10 of 18 Old 08-05-2014, 06:59 AM
Phillipjon's Avatar
Quoted: 76 Post(s)
When you do this mod do you use a 6.0 fan clutch or the 7.3 fan clutch?
1996 F350 4X4 CCLB SRW
Full Force Stage 1.5-Swamps IDM-Efuel-Bosch 17* HPOP-Melling LPOP-Intercooled-Deleted pedestal-Stancor glow plug relay-1.0 housing-Isspro EV2's-Sky RSK-SD front and rear springs-Tru cool tranny cooler-Built Tranny-CCV mod-6 position chip running TW tunes-6637-3" down pipe to 4" straight pipe-Grab handle mod-Dual lighted visors-3.73 Gears-Warn hubs-SD aluminum rear diff cover-Dual front shocks-295/75/16 Toyo Open Country AT2's
Phillipjon is offline
Tags
clutch , maintenance , seals , turbo , up pipes
