Front Crankshaft Seal - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-02-2009, 06:58 AM Thread Starter
Transmission or Injectors
lwillson's Avatar
Good Day,
I think I am going to change my front crank seal. Its been dripping pretty good for a while now, and its time to close off that leak.
Are there any tricks for doing it? Anything to look out for?
According to the service manual, it looks pretty straight forward.
lwillson is offline
post #2 of 5 Old 02-02-2009, 07:12 AM
International Threat
Marty's Avatar
I'll be doing two this Sunday... I'll let you know how it goes.
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #3 of 5 Old 02-02-2009, 07:16 AM Thread Starter
lwillson's Avatar
I ordered the crank seal and the gasket and oring set to do the oil cooler. They should all be here tomorrow. Theoretically, tomorrow night I should be back together.
Tonight I plan to clean up the mess the oil cooler left when I took it off. It was quite the surprise when I let the last bolt out of the filter end.
lwillson is offline
post #4 of 5 Old 02-04-2009, 06:31 AM Thread Starter
lwillson's Avatar
I got the parts yesterday, and got it installed last night. I had to make a tool for installing the crank seal, and it worked out pretty easy.
The tool was pretty simple, and worked surprisingly well. The hardest part of it was getting something the same size as the crank seal for pressing it into the engine. I found that the top idler pulley was the same size as the crank seal. I had the pulley off anyways because I was changing the bearing in it.
I started with a piece of 16mm threaded rod about 6-8" long. It can probably be shorter, but I wasnt really paying attention to how much room would actually be there because I had the rad out. I threaded the rod into the crankshaft, then slipped the crank seal over it, then the idler pulley, then a piece of plywood with a hole cut in it (substitute anything larger than 4"diameter, I had a piece of plywood kicking around, so thats what I used), then a washer and the nut. Then just tighten the nut, and it will press the seal into the engine.
Since I didnt have a puller to get the bearing sleeve off of the Harmonic Balancer, I used a chisel and kept scoring it downwards until it snapped. If you heat up the new sleeve, before installing it, it will expand enough to make installing it a lot easier
I also needed to use the threaded rod for the harmonic balancer, as the bolt that holds it in isnt quite long enough to reach the crankshaft when the balancer just sits on the crankshaft. I used a 3/4" nut over the threaded rod, plus the balancer washer and another washer to make up the space difference from the outside edge of the balancer to the middle of it. Tightened up the nut again, and the balancer was on. Removed the threaded rod, installed the bolt and washer, and everything was back together.
I attached a picture of my very basic seal installer. Hope this helps
Name:	Crank Seal Installer.JPG
lwillson is offline
post #5 of 5 Old 06-13-2012, 06:59 PM
rocktamer's Avatar
Thanks for the post! I am looking to do this and wasn't quite sure how it would all play out. How did you pull the balancing wheel off?
rocktamer is offline
