'97 7.3l shuts off for no apparent reason - Ford Powerstroke Diesel Forum
post #1 of 10 Old 08-03-2014, 11:25 AM Thread Starter
Hi Guys, I'm new to forum, but have had my '97 F-350 w/7.3l since new. It has many bolt on mods. but has never left me stranded anywhere for 195k miles.
Now every once in a while it shut off when I come to a stop, but will fire up right away. Sometimes it will do it several times and then won't do it a long time.
The truck has always been well maintained (serviced regularly).
Can anyone make a suggestion way it's doing this. By the way it's not throwing any codes.
Thanks in advance, Steve.
Sorry, posted in wrong forum. Mod please delete. I will repost in correct forum.
reride is offline
post #2 of 10 Old 08-03-2014, 11:27 AM
scuffs *****
Tyler's Avatar
Send a message via AIM to Tyler
The ICP sensor is going bad or the CPS is going bad. My old truck did the same exact thing. If you try to restart it without shutting off the ignition wil lit restart or do you have to turn the ignition off first?
Sr. Engineering Tech/OPS Technician @ Your local cable company.
1997 7.3L PSD
| 4" MBRP Exhaust | S&B CAI | Torque Converter Lock-Up Switch | Exhaust Brake | FPR Shim |DB High Torque Starter | 188,000 Miles | Xtreme Daily Tune |
SOLD
2014 Ford Fusion SE
| 1.6 EcoBoost | 6-Speed Manual | The basics and some goodies |
Tyler is offline
post #3 of 10 Old 08-03-2014, 11:28 AM
Quoted: 27 Post(s)
Possibly a CPS going out. Wrong section btw and welcome to the org.
-Kris
01 cclb f-350 srw-463hp/1025ftlbs PHP Dyno (extreme tune)
leveled with 285's on 17'' XD Spy's
Autometer gauges (boost, trans, egt, fuel)
4'' straight pipe
DIY 6637
Powerstruck 160/30's
Hydra-Powerstruck and Dan K tunes
38r
CNCFab fuel & hpop lines
Sam Wyse stage 2 trans.
Originally Posted by Dave View Post
Why delete something thats truthful? Paid vendor status isnt like the mafia youre not paying for protection from negative feedback here
strokin-7.3 is offline
post #4 of 10 Old 08-03-2014, 11:32 AM Thread Starter
reride is offline
post #5 of 10 Old 08-03-2014, 11:39 AM
scuffs *****
Tyler's Avatar
I answered you in you'r other thread. Change the CPS sensor.
1997 7.3L PSD
SOLD
2014 Ford Fusion SE
Tyler is offline
post #6 of 10 Old 08-03-2014, 11:55 AM
erics diesel's Avatar
Sounds like cps to me
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #7 of 10 Old 08-03-2014, 12:14 PM Thread Starter
Forgive my ignorance, but CPS is the crankshaft position sensor, correct. I feel like a dummy because I have never had to work on it. It's been that good of a truck.
reride is offline
post #8 of 10 Old 08-03-2014, 12:18 PM
Quoted: 21 Post(s)
CPS= Cam position sensor. I just changed mine, got it from international for $45.
its one bolt to change it, in the 10 o'clock position when looking at the crank pulley from the front. lube the seal on the new one before installation.
Syndicated_cdn is offline
post #9 of 10 Old 08-03-2014, 12:25 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
Feedback Score: 4 reviews
Failing cam sensors are known for this. Remember the OBS trucks use a different sensor than the super duties
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #10 of 10 Old 08-07-2014, 02:57 PM Thread Starter
Thanks everyone!
I just got a CPS today and will install it this weekend & will post when done and let everyone know how it turns out.
Thanks Again,
Steve
reride is offline
