8inch lift with track bar issue - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-31-2014, 02:22 PM Thread Starter
drive one's Avatar
Hey guys, I have a 1996 f350 cclb, 8inch suspension lift with 3inch body lift on 41s with a KP dana 60 front differential. The track bar mount on the driver side frame keeps breaking off and I'm wondering if I even need to run it or if i need to find a better welder to get this issue resolved.
drive one is offline
post #2 of 4 Old 08-01-2014, 08:43 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 45 Post(s)
Not a 4x4 guy but am a MillSmith. For that much lift you are putting a lot of side load on the track bar and no wonder that it keeps ripping itself off. To do it right it needs to be braced all the way across to the other side. So mount the track bar where it goes and then bolt in a bracket on the passenger frame in the same place. weld bracing from the right to the left side. Triangle brace the cross member you just made to the drop arm of the track bar.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
The Following User Says Thank You to BigFuel For This Useful Post:
drive one (08-01-2014)
post #3 of 4 Old 08-01-2014, 02:52 PM Thread Starter
drive one's Avatar
Thanks Bigfuel, that makes sense ill have to plan a day to tackle that project!
post #4 of 4 Old 08-03-2014, 06:01 PM
Diesel_brad's Avatar
Quoted: 4 Post(s)
Who mounted it on the drivers frame rail?
Looking for Blue 40-20-40 seats. PM me !!!!!!!
Diesel_brad is offline
