95 CCLB ZF5 2 wheel exhaust Purchase? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-31-2014, 12:50 PM Thread Starter
pk64f100's Avatar
I have a 95 CCLB ZF5 2 wheel drive and and I want to change old exhaust system from turbo back which kit comes that I do not need to cut on anything on my truck, if they make one? I have heard that "MBRP S6218P Turbo Back Single Side Off-Road Exhaust System with Aluminized Downpipe" does not fit eventhough they claim it does. I would love to get a single 4" but would also be open to a 5" system or even a single or dual stack system but it would have to be black. Thanks
pk64f100 is offline
post #2 of 4 Old 07-31-2014, 03:00 PM
BANNED by Kris
BigFuel's Avatar
Quoted: 57 Post(s)
All systems for our trucks are general setups. They all should fit but some individual kits are a little short or a little long. Also, if your body mounts are worn then you will have even more problems with fit. Trials of mass production and old trucks. All kits require at least one cut though, short of taking the engine out or cab off you must cut out the stock downpipe.
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #3 of 4 Old 07-31-2014, 04:54 PM
Patrick Feeley's Avatar
Quoted: 17 Post(s)
Many times the downpipe will hit one of the "jig mount" ears on the 5-speed tranny. I had to cut the ear off my tranny on the 94. No big deal. Cheers!
Patrick Feeley is offline
post #4 of 4 Old 08-01-2014, 06:14 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Also gonna have to bend or cut the cab pinch weld
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
