loss of torque...wtf, fixed - Ford Powerstroke Diesel Forum
post #1 of 16 Old 07-31-2014, 04:33 AM Thread Starter
twitchcvma's Avatar
OK, guys, once again this forum kicks ***. I posted a problem / question a few weeks ago about towing 2000lbs up some colorado mountains, blowing smoke, and high EGT's. Y'all came back with a boost leak.
Yup. I popped the hood and started looking around. The intake manifold, the black Y lookin' thing behind the fuel filter was askew. It was off just a bit. The boots were holding it on, but a visual was easy to see that it wasn't flush. I loosened up the clamps, readjusted the seating position, made sure all was flush and tight. Tightened up the clamps. And WOW. what a difference. Before if I got into the accelerator I might make 5 lbs of boost. That's it.
Now, I make 5lbs of boost just leaving the stop light. Getting on it I can hit 15lbs. The truck seems a lot more responsive. Told my buddy I wanted to hook up his utility trailer and go driving in the mountains again just to see and feel the difference.
Thanks to all
T
twitchcvma is offline
post #2 of 16 Old 07-31-2014, 06:22 AM
Quoted: 9 Post(s)
Sweet! Glad you were able to find and fix the problem. You are right, this is one of the best resources on the web. Lots of great people with way more experience and knowledge then any service tec at any shop. Best of all we help each other for FREE and keep the money in the workin mans pocket.
1997 Crew Cab Long Bed 4X4 (DRW Conversion) Auto. 280K miles
Stainless Irate Bellowed Up Pipes
Fresh Turbo with 1.0 Housing & Wicked Wheel II, 3" downpipe with 4" exhaust, Intercooled, 6.0 Fan, 39 gal rear fuel tank + 70 gal Transfer Flow in the bed, Hydroboost, Completely New Suspension (Springs, Shocks, Bushings),08 Rear Diff Cover, Baby Swamps, Hydra Chip with Swamps Tunes, and Swamps IDM, Dually Swap, Tru-Trac locker in the rear, Red Head Steering Box and Borgeson Steering Shaft
ChallengerRV is offline
post #3 of 16 Old 07-31-2014, 08:19 AM
Quoted: 861 Post(s)
Feedback Score: 3 reviews
You should be able to hit more than 15lbs, but that's way better than before
Corey@CNCFAB is offline
post #4 of 16 Old 07-31-2014, 08:49 AM
Question on a 100% stock 94-97 truck how much boost should you be able to make??
the reason I ask is I have a 1995 truck all stock and its makes 15 pounds of boost.
jmcclesk is offline
post #5 of 16 Old 07-31-2014, 08:59 AM
Quoted: 9 Post(s)
When my truck was stock I would have to have a load on the back to hit 15 pounds. Now with my mods below I hit 25 - 30 pounds no problem.
post #6 of 16 Old 07-31-2014, 09:12 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Id say thats about right for a stock OBS truck Corey, the turbo is bigger so you wont build as much as a SD would. Plus the smaller sticks make it hard to get above 20.
See above^^
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
The Following User Says Thank You to Rammstein1224 For This Useful Post:
jmcclesk (07-31-2014)
post #7 of 16 Old 07-31-2014, 09:21 AM
thanks for the input. When you say smaller sticks, you mean injectors correct???
jmcclesk is offline
post #8 of 16 Old 07-31-2014, 09:33 AM
Chapter Director
Quoted: 5 Post(s)
Yes sir, 94.5-97 OBS had 90cc(save cali-models) and l99+ had 120cc
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #9 of 16 Old 07-31-2014, 09:56 AM
Ok one more dumb question (promise last one). the door sticker says conforms to federal standards. the sticker on the valve cover says conforms for federal AND California standards. build date 05/95. Was original sold out of Chico California. Can I assume it is a CA model truck?? I guess the best way is to check the calibration code on the computer.
thanks for all the info.
jmcclesk is offline
post #10 of 16 Old 07-31-2014, 10:12 AM
dr.deere's Avatar
Quoted: 19 Post(s)
See above^^
No it's really not that hard to get above 20 on a stock motor I do it routinely in both my 94 and 97 with stock injectors and no tuning
Sent from AutoGuide.com App
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
