Ignition question- Key out still running? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-28-2014, 03:01 PM Thread Starter
pk64f100's Avatar
I went to move truck yesterday and turned key off and the truck did not turn off, it kept running even after the key was removed. I put key back it and moved it around a little and finally got it to turn off. I drove it all day yesterday and today without anymore issues. Anyone ever see this before? Thanks
pk64f100 is offline
post #2 of 6 Old 07-29-2014, 04:00 PM
Quoted: 84 Post(s)
Yup I could pull my key out while running. Got a new cylinder and keys from rock auto and had it changed out in about 10 minutes
White95f250 is offline
post #3 of 6 Old 07-29-2014, 04:16 PM
ZMANN's Avatar
Quoted: 1570 Post(s)
if u do the cylinder and want to have the same key let me know ebay has a great seller that will get you hooked up with just a picture of your existing key
We Miss you Ronnie
ZMANN is offline
post #4 of 6 Old 07-29-2014, 04:21 PM Thread Starter
pk64f100's Avatar
what is the contact info
I definitely would entertain that then I can keep my doors and ignition the same. thanks.
pk64f100 is offline
post #5 of 6 Old 07-29-2014, 04:37 PM
Quoted: 84 Post(s)
I wanted to but it adds to the anti theft part having 2 keys to get in and turn it on.
post #6 of 6 Old 08-04-2014, 02:45 PM Thread Starter
pk64f100's Avatar
Check out these pics and info
My son thinks it is something else because the tach and lights at dash loose power when key is turned off which he thinks means the ignition switch is working. look at the pics and see if you think this would cause switch failure or maybe arm behind ignition cylinder? Thanks
ID:	319969   Click image for larger version
ID:	319977   Click image for larger version
pk64f100 is offline
