Im lost here: Need suggestions on turbos... - Ford Powerstroke Diesel Forum
post #1 of 18 Old 07-28-2014, 01:46 PM Thread Starter
MrOneEyedBoh's Avatar
Quoted: 13 Post(s)
Feedback Score: 11 reviews
So my cousin has a 97 with baby swamps and then normal 6pos chip. I think its a TS. ( no custom tunes )...
He wants to go up to a D66 for now, as the baby swamps on the TS chip tuning it pretty smokey. Plus a little more power is a plus too.
I was doing some browsing and I see that there is a DIY66 and the Beans D66. Any other options out there? I dont know where to start looking at for him, so any suggestions are appreciated.
Thanks guys.
BTW Im a 6.0 guys, so this is all new to me.
MrOneEyedBoh is offline
post #2 of 18 Old 07-28-2014, 01:51 PM
dannanw's Avatar
Quoted: 66 Post(s)
Garage
for a stright drop in D66 is about the only option (I've got a E99 and in the same boat). Unless you either 1. update to all SD parts (about 2k) or 2. go all out with a "normal" mount t3/t4 type set-up such as the h2e whitch has its own pedistal (3K+ depending on brand/type).
but more important fact he/you are missing is to get custom tunes and that'll be more HP and less smoke
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #3 of 18 Old 07-28-2014, 01:55 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
This^^^^^^
But drop in easy is beans d66, barder has a DIY 66mm turbo, and there is also another company I can't remember the name of
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 18 Old 07-28-2014, 02:08 PM Thread Starter
Quoted: 13 Post(s)
Thanks guys,
It seems like you have to drop the trans to install a turbo? Or maybe its easier to drop the trans? lol.... I cna have my 6.0 turbo out in about 15-20 mins no problem.
Who's tunes should he get?
post #5 of 18 Old 07-28-2014, 02:48 PM
pk64f100's Avatar
1995 Babby Swamps and TS 6 pos
I have a 95 with Baby Swamps, TS 6 pos and it does not smoke and runs very well real strong especially when Turbo kicks in. It is very smooth and I believe it has the 150/146 injectors if I am not mistaken. I keep it on 6, the PO said he puts it in #1 when towing and #2 when cold outside to start other than that it stays on #6. The rebuilt motor was 100,000 miles ago. Truck also has a A&B intake. I hope that helps sounds like we have similar set ups.
pk64f100 is offline
post #6 of 18 Old 07-28-2014, 03:40 PM Thread Starter
Quoted: 13 Post(s)
Okay maybe he just needs better tunes first. I know how critical tunes are for the 6.0s... I wouldnt think TS would ship their switch with terrible tunes. Anyway thanks all.
post #7 of 18 Old 07-29-2014, 02:28 AM
pk64f100's Avatar
6 position switch and running issues
Chech the contacts where chip is wired to computer very easy if there is a connection that is not perfect and needs to be cleaned this possibly could cause what is happening. I wish I knew more buy brand new to the 7.3 diesel community. Best of luck!! I have one question how is the 6 pos switch mounted on his truck could you send me pics? Thank you!
pk64f100 is offline
post #8 of 18 Old 07-29-2014, 07:22 AM
So I'm running a 66mm turbo thats made by PDR Diesel, It came with a 1.0 housing for a quicker spool. It cleaned up my Baby swamps, even with good tuning (swamps and live tuned customs) It was smokey and hot with the stock TP38, the 66mm charger cured this big time. Simple bolt in, 360 thrust bearing, 1.0 exhaust housing, Billet Compressor Wheel. 66/88 Comp wheel.
All for $100 less than a Bean D66. for a better turbo.
1995 F350 CCLB
7.3L Powerstroke
ZF-5 w/ South Bend 1944-5OK
Baby Swamps
PDR Diesel Super 66 1.0 Housing/Billet Wheel
TS 6 Position
6.0L Intercooler
PDR Diesel Intercooler Piping/Boots
Intake
3in DP 4in SS exhaust
US Gear Overdrive
Pacbrake
310KM (193MI)
matt-jenkins is offline
post #9 of 18 Old 07-29-2014, 09:44 AM
Delivers Pizzas For Fun!
ol_Blue97's Avatar
Baby swamps aren't enough to spin a 66 properly. Rebuild his stock turbo with a WWE and new gearhead tunes...... just my opinion
FRANK THE TANK
DIY INTAKE - HYDRA CHIP - MARTY'S E-FUEL - 250/200s
05 AXLE SWAP 3.73 - 2.5" PURE PERF. LIFT COILS - FOX SHOCKS
BTS TRANS - TYMAR DOWN PIPE - 4" EXHAUST
Waiting To Be Installed... gtx4294r, studs, springs, HPOP?
Originally Posted by STROKED_NY_023 View Post
You are so smart Frank, I dont care what Terry says.
ol_Blue97 is offline
post #10 of 18 Old 07-29-2014, 09:52 AM
I dont have any issues lighting my 66mm with my Babies, 1.0 Housing helps with that though I'm sure.
Also the blade pattern on the compressor wheel will also dictate the results. If you have a 11+0 style billet wheel then you will be taking a step backwards when compared with a 6+6 syle billet wheel or cast wheel.
