Engine & Trans Temps While Towing - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-28-2014, 12:08 PM Thread Starter
This weekend when hauling my travel trailer (approx 4500 lbs), I noticed that the engine and trans temp was climbing higher than usual. I went most of the way on relatively flat ground between 55 to 60 MPH with very little stopping and accelerating. The outside temp was probably 95 degrees. The engine temp at the highest was reading right between the "A" and the "L" in (normAL), but normally stayed between the "M" and the "A" (norMAl). The trans temp at the highest was around 230 degrees, but usually stayed 210-220. On hot days like that, my engine temp usually stays below the "M" and the trans ranges between 180-195 when not towing.
Should these towing temp ranges be of any concern? The truck didn't exhibit any problematic signs while underway. Granted, this was the hottest day I've towed anything heavy, but I've just never seen the temps go that high.
1996 F350 4x4 CCLB E4OD
Stage 1's, Tony Wildman Tunes, 6637 Intake, 5" Stainless Exhaust, Bilstein 5100's, FPR Spring Mod, Dark Blue CPS, Pillar Gauges (trans temp, pyro, boost), 6.0 Fan Mod, Tru-Cool Max Trans Cooler (and SD Cooler Lines), HPX Crossover, Alum Radiator, 203 Deg DieselSite Thermostat, '08 SD Alum Finned Rear Diff. Cover, PMF RSK (w/ V-Codes)
majorgator is offline
post #2 of 12 Old 07-28-2014, 12:58 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Look into a larger Trans cooler, you should be able to keep it below 210 all the time with those weights, as far as coolant temp, get a hose and spray the radiator off, you may have dirt between the rad/condensor keeping it from being as efficient as it should be
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 12 Old 07-29-2014, 09:28 AM
SoCalPwrStrk's Avatar
Larger trans. cooler is the way to go, but your engine temp does seem high. I tow my trailer (14k lbs) up grades in 90 degree heat and my engine temp never gets above the M, plus my radiator has a 6.0 trans cooler and an intercooler in front of it. What were your EGT's running? I ran my trans temp up to 240 once, after I added the 6.0 cooler it hasn't broken 200.
"Big Truck" 1997 F-350 CC DRW 4x2 Cali model
Diamond Eye 3" dp to 5" straight pipe, DIY 6637 intake, Pillar gauges, 6.0 trans cooler, Intercooled, TS 6 pos. chip with TW Tunes, 1.0 Housing, Barder Billet Wheel, EBPV Delete
"Baby Truck" 1999 Ranger EC 5 speed 3.slow
Camburg Long Travel, Billit upper arms, Fox dual rate coilovers and double bypass in front, Deaver race pack w/ fox double bypass in rear, fiberglass fenders, 16x8 American Racing Mohave Wheels
SoCalPwrStrk is offline
post #4 of 12 Old 07-29-2014, 11:05 AM Thread Starter
Sure, that'll work. But at such a small weight and strain, why won't the stock trans cooler work? I've hauled heavier before on my flatbed without similar issues.
These were anywhere between 800 to 1000 while under power. If dead flat for a while, it would drop down to around 600. Of course, under acceleration I'd make it up to 1200 or so.
post #5 of 12 Old 07-29-2014, 11:46 AM
with your engine temp so high, it might have been making your trans temp go even higher since it passes through the radiator then the trans cooler. But i could be way off
post #6 of 12 Old 07-29-2014, 12:16 PM Thread Starter
Yes, that's true, the 2 run together. There is some correlation in temps. When the engine temp falls, the trans temp falls as well.
post #7 of 12 Old 07-29-2014, 01:13 PM
Quoted: 4 Post(s)
I had to replace the radiator on my 95 F350 because where the tranny fluid ran through the radiator I only had 35% open. New radiator now and no tranny temps over 170 here in AZ. In fact I had it up to freeway speeds yesterday when ambient temp was 105 and my tranny never went over 170.
timlsalem is offline
post #8 of 12 Old 07-29-2014, 01:20 PM Thread Starter
There ya go, throwing more ideas into my already mod-filled mind LOL
Seriously, though, how were you able to tell that. Did you have to disassemble and get a visual? That makes plenty of sense regarding higher temps.
post #9 of 12 Old 07-29-2014, 02:53 PM
Quoted: 4 Post(s)
No. I had my mechanic check it out when I was having high temps in the tranny gauge. There's a gauge he hooked to the line that gave the reading of 35%. I don't know the name of it but maybe some of the hardcore diesel people on here can tell you.
post #10 of 12 Old 07-30-2014, 12:34 PM
Quoted: 2 Post(s)
To verify, you're not running the 203 degree thermostat, correct?
The transmission temps are a bit high, but the engine temp is within reasonable range. You might consider replacing the thermostat at some point, since they often fail in a "Doesn't open quite as far as it should" manner, but that's usually best done with a water pump since the thermostat bolts seize into the water pump and snap off with alarming regularity.
Syonyk is offline
