My OBS "build" - Ford Powerstroke Diesel Forum
post #1 of 22 Old 07-27-2014, 03:52 AM Thread Starter
ars5147's Avatar
Quoted: 124 Post(s)
My OBS "build"
So it's getting close to being done, so I figured I'd share what I have so far.
I'm not doing this myself as I have no time, but a great shop is doing the work for me.
The list:
Adrenaline HPOP
205/100 hybrids
T4 mounted S366, billet wheel
The shop built their own fuel system, fuel labs components
Of course new tuning via TS chip
Replaced the Swamps IDM under warranty, it stopped working properly after about 3 months
New UVCHs
Fixed the leaking front and rear mains
Should be done soon, here are some pics.
Name:	7.3 reg return.jpg
ID:	316714   Click image for larger version
Name:	7.3 s366 billet wheel.jpg
2008 F250 CCSB 6.4
1997 F350 CCLB 7.3
2011 F150 SVT Raptor
ars5147 is offline
post #2 of 22 Old 07-27-2014, 06:41 PM
the baconator
terryknight's Avatar
Quoted: 146 Post(s)
in your pic it does not appear that the regulator is on the return side. that is an issue. otherwise well done
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 22 Old 07-27-2014, 06:55 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Awesome stuff going in, can't wait to see some numbers
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 22 Old 07-28-2014, 01:50 AM Thread Starter
ars5147's Avatar
Quoted: 124 Post(s)
I have no idea if it matters which way the fuel flows through the head. I'll bring that up to them though.
Thanks
2008 F250 CCSB 6.4
1997 F350 CCLB 7.3
ars5147 is offline
post #5 of 22 Old 07-28-2014, 01:51 AM Thread Starter
ars5147's Avatar
Quoted: 124 Post(s)
Me too, I just want it back! Been a while since I last drove it.
2008 F250 CCSB 6.4
1997 F350 CCLB 7.3
ars5147 is offline
post #6 of 22 Old 07-28-2014, 04:07 AM
Quoted: 50 Post(s)
AFAIK it doesn't matter. Dude I met here who did a WVO has his dino-diesel running one direction (IIRC, back-to-front) and the WVO running the other.
madpogue is offline
post #7 of 22 Old 07-28-2014, 04:17 AM
the baconator
Quoted: 146 Post(s)
didn't think about t fact the could have reversed the flow....
post #8 of 22 Old 07-28-2014, 08:12 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 50 Post(s)
Just an opinion, I would think that it does indeed matter where this motor is concerned. Since this motor is being build to make real power and not for the case of towing reliability or high MPGs please consider that the motor fires hole 6 right before hole 8. Under hard acceleration the fuel would be pulled by number 6 to leave 8 "dry". There are two reasons for having the heads flow back to front in these motors, air bubbles move uphill and 6 starves 8.
Just an opinion...great work in there OP!
Matt
-'97 Mini Monster
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-'15 F350 6.7L DRW 4x4
BigFuel is offline
post #9 of 22 Old 07-28-2014, 02:01 PM Thread Starter
ars5147's Avatar
Quoted: 124 Post(s)
I assumed that the flow could be reversed since it is a "common" fuel rail.
Big fuel, that is a good point.
All good things to think about. As to what point it would be starved, how could the starvation be measured?
2008 F250 CCSB 6.4
1997 F350 CCLB 7.3
ars5147 is offline
post #10 of 22 Old 08-18-2014, 05:43 AM Thread Starter
ars5147's Avatar
Quoted: 124 Post(s)
More pictures. The truck is done. Made 359 and 590, but should be more b/c the tranny was acting up and we didn't want to break anything.
It is amazing how fast it is now. A little smokey but tuning can be tweaked.
ID:	325938   Click image for larger version
ID:	325946   Click image for larger version
ID:	325954   Click image for larger version
2008 F250 CCSB 6.4
1997 F350 CCLB 7.3
ars5147 is offline
