Live data and code reader? OBDI - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-26-2014, 08:45 PM Thread Starter
bdemutis's Avatar
Quoted: 9 Post(s)
I have a 1994.5 7.3 power stroke and was wondering what's a good code reader I want something that shows the codes and live data.
bdemutis is offline
post #2 of 2 Old 07-27-2014, 07:45 AM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
If you 94 has not been reflashed (many have been, so it would be good to know), I would get it reflashed to a later (say 1996) level. The original programming didn't offer much of anything in the way of diagnostics. The only time my 94 was at a dealership for a problem (on vacation with the fiver in tow), the dealer reflashed it to an ALF4 so he could run diagnostics on it. After a reflash, you can then run something like AutoEnginuity, etc. If your dealer can't do it, check with somebody like DP Tuner. Cheers!
Patrick Feeley is offline
