Starting/ignition problem - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-24-2014, 06:30 PM Thread Starter
Sorry I have been posting so much lately but I have been real busy and neglected the ole 7.3 over the past few months and have some catching up to do.
I had a problem the other day when I went to start it. I had turned the key to let the GPs warm up and as I was waiting for the WTS light to go off everything surged (lack of power) then it went back to dinging and normal. A second later everything went dead including the radio - nothing happened when I turned the key. It was like someone had just flipped a switch to the batteries. I got out to check my battery cable connections and all were good after a little jiggle. I got back in and it fired up like normal.
I have had a couple similar power "sputter" type issues when starting although it has been very infrequent.
Thoughts? I considered it could be the starter relay but don't know enough about how that works
mathewsz7 is offline
post #2 of 5 Old 07-25-2014, 04:54 AM
Quoted: 75 Post(s)
I had the same issue but pulled the battery cables and cleaned everything real good with a wire brush. Check your grounds and starter connections as well. Mine was a loose battery cable.
White95f250 is offline
post #3 of 5 Old 07-25-2014, 06:14 AM
sbluke55's Avatar
Quoted: 525 Post(s)
Garage
I agree with him. Make sure your cables are good. If not replace them. Then clean everything up real good and tighten everything down good.
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #4 of 5 Old 07-25-2014, 08:11 AM
Quoted: 2 Post(s)
The starter relay has nothing to do with what you saw.
The battery connections, on the other hand, deal with 600-700A (minimum) while starting the motor - ~160 for the glowplugs, ~500 for the starter. Maybe a bit more.
Go clean and tighten all 4 battery connections. If it does it again, look into where the cables connect.
Syonyk is offline
post #5 of 5 Old 07-25-2014, 11:07 AM
Klong2194's Avatar
Same thing happened to me last night, Also under acceleration my gauges, and headights will flicker sometimes. And then rolling up my window or turning my lights on will shut my radio and gauges off. I think I have some wiring issues. But ill have to check the battery connections for the starting issue.
96 F250 ccsb. Gloswshift gauges, Ts 6 Pos chip, Exhaust and intake.
Klong2194 is offline
