1997 Front Hub issues - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-23-2014, 03:09 PM Thread Starter
Quoted: 22 Post(s)
Ok, so I took my truck to a shop for an alignment. They call me and say my bearings are loose and need repacking first. I agreed, a couple hours later, they tell me they can't get the hubs apart because they don't have the right socket. So I brought them a hub socket made by powerbuilt which is listed for F250's, Dana 50 & 60 axles. Its a 2.5" round socket with 4 internal lugs. They called me today and told me it was still a no go, saying something about a 42mm 12 point socket.... *sigh* i told them to get the toe as close as possible and cut me loose.
My truck has been converted to warn standard manual hubs, is there really a unique socket for this set up or are these guys just morons?
I went to warn's website and see theres a listing for a nut service kit or whatever, but no pics. IF there is a special socket, could someone post a pic for me??
Truck is a 97 ECSB 4x4.
Thanks!
Syndicated_cdn is offline
post #2 of 11 Old 07-23-2014, 03:24 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
What kind of shop is going to recommend a service they can't perform, sorry I've never used warn hubs
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #3 of 11 Old 07-23-2014, 03:32 PM Thread Starter
Quoted: 22 Post(s)
That was my first question.... their answer was that they don't have anyone familiar with these rigs.
I used to work for Ford as a mechanic like 10 years ago right out of high school, other than for tires, I've never sent my vehicles to any shop since then.
This is why....
post #4 of 11 Old 07-23-2014, 05:49 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Not sure if this helps, but I use a NAPA 3246 on my 97 F250 with manual hubs. Cheers!
Patrick Feeley is offline
post #5 of 11 Old 07-23-2014, 06:46 PM
leojr's Avatar
Quoted: 4 Post(s)
I put a few pics in my thread (see my build thread linked below) as I went through mine, maybe they might be helpful?
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
leojr is offline
post #6 of 11 Old 07-24-2014, 04:49 AM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
your truck has been converted? as in it had auto locking hubs? did they/you swap to the manual type spindle nut?
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #7 of 11 Old 07-24-2014, 06:40 AM Thread Starter
Quoted: 22 Post(s)
Well I assume they were converted to warn hubs. I bought the truck in december, and the hubs said "warn" on them.
I was under the impression all 96-97 f250 4x4's came with auto hubs.
Either way, I got the truck back from the shop last night and they were able to get the toe aligned to within spec despite the loose bearings.
I still want to take it apart this weekend and see whats what, so the question remains, is there any other socket than the 2 1/2" round socket with the 4 internal lugs? I don't have a NAPA anywhere nearby, and the place i use carries "power built" tools:
POWERBUILT
Also, now that it's aligned, theres still a large amount of slop, or deadband in the steering wheel before it starts to move the wheels, is a steering box in my future??
post #8 of 11 Old 07-24-2014, 07:10 AM
the baconator
Quoted: 143 Post(s)
you can tighten the steering box up, there should be a nut and an allen headed bolt (some are slotted though) loosen the nut tighten the bolt. only do it 1/4 turn at a time. not all 96-97s had auto locking hubs, some came with standard manual ones. the auto spindle nut is different from the manual one. the socket you have should fit the manual nuts.
post #9 of 11 Old 07-24-2014, 07:41 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 44 Post(s)
Terry, we talked to a kid a month or so ago that had the standard hub nut on one wheel and some sort of aftermarket on the other. OP, lift the tire off the ground and tap the hub nut off with a thin chisel or roll pin punch. It's not that tight. Replace with the right hub nut.
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #10 of 11 Old 07-24-2014, 09:08 AM
the baconator
Quoted: 143 Post(s)
hmmm...... don't remember that one.
