Powersteering pump? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-22-2014, 04:00 PM Thread Starter
deezelfromRofo's Avatar
Powersteering pump?
Any advice would be appreciated. Thanks in advance
97 ford f250 HD supercab xlt longbed
banks intercooler
banks power pack
285 75 16's
3" dp
DIY tymar intake 6637
stancor 586-902
B&W tow n stow
triple pillar gauges:
Banks Dynafact boost gauge
Banks Dynafact egt gauge
ISS Pro trans temp gauge
Hayden 32k transcooler
kittyless and unmuffled
deezelfromRofo is offline
post #2 of 4 Old 07-22-2014, 06:04 PM
Shadowfax's Avatar
Quoted: 13 Post(s)
try to clean it up really good and see where the leak is actually coming from. Could be a hose or the gearbox or the pump.
If you do the pump, when you put the pulley on the new pump don't just press it on all the way like I did the first time I did it. Make sure it lines up with the rest of the pulleys or it will squeak and you will chase it forever.
If you have a helper stand there and watch it while they turn the wheels back and fourth, you may be able to see where its coming out.
Also make sure the cap is on.
2015 f350 lariat
2003 Jetta TDI 5spd
Shadowfax is offline
post #3 of 4 Old 07-23-2014, 05:19 AM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
what he said. my guess is it's just a hose. autozone/napa sell them but i think it's a part that needs to be ordered
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #4 of 4 Old 07-23-2014, 05:29 AM
Quoted: 48 Post(s)
A little more info would help. You show a picture of the box, but ask if it's the pump. Maybe a picture of the pump would help. Are you sure that that is ATF you're seeing, and not something else leaking from above? Is the level low in the pump?
madpogue is offline
