1996 PSD oil pan issue (not the standard issue) - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-20-2014, 08:54 PM Thread Starter
I have a 1996 powerstroke F250. At some point the previous owner just installed a block off plate where the dipstick once was. Any help on how to get a dipstick installed without pulling the engine?
Unrelated but what is a rough estimate on a engine rebuild if a shop does all work?
blanco_xj is offline
post #2 of 4 Old 07-22-2014, 11:16 PM
Klong2194's Avatar
not sure on the dipstick, but a guy in Georgia that runs powerstrokehelp.com does is for a little over 5000. He uses uship, or drop off.
Klong2194 is offline
post #3 of 4 Old 07-23-2014, 02:42 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Can you uninstall the block off plate at all? There is a company that makes the "dipstick fix" which is a new part you put in and drop the old retainer ring in the bottom of the pan, and just need to get the tube and dipstick, should be easy enough
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 4 Old 07-23-2014, 04:17 AM
the baconator
terryknight's Avatar
Quoted: 150 Post(s)
the part kris is talking abut is from strictly diesel. about $300
Strictly Diesel Dipstick Adapter Repair Kit
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
