Dieing - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 11 Old 07-17-2014, 05:20 PM Thread Starter
Dieing
my 95 ford 7.3 will die from time to time, it starts back up most of the time , I checked the wiring and replaced the ignition switch and it still does it. any help would be awesome.
michaellee74044 is offline
post #2 of 11 Old 07-17-2014, 05:49 PM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
does it die upon start up? idling? driving down the road? all of the above? mostly likely CPS camshaft position sensor. they are known to fail on the 7.3
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 11 Old 07-17-2014, 06:01 PM
Powerstroke Techie
justinmix's Avatar
Yeah, need a little more info on the symptoms, like how often, and what was going on when it does it, and how hard was it to get started again. Did you happen to check codes? Did it seem to happen more when the truck was facing up hill?
justinmix is offline
post #4 of 11 Old 07-18-2014, 06:12 AM
Quoted: 74 Post(s)
CPS and my ICP was causing the random turn offs but hard shifting and throwing a code too. Throw a CPS in it, make sure its a Ford brand.
White95f250 is offline
post #5 of 11 Old 07-19-2014, 04:48 PM Thread Starter
it dies mainly after warms up, some times it starts right up and other times its hard to start. I've changed the cps and the irp, but really not a name brand.i notice it is taking a little longer to start up.
post #6 of 11 Old 07-19-2014, 07:25 PM
the baconator
Quoted: 143 Post(s)
do you have a way to run tests? specifically for the HPO system. icp, duty cycle, etc
post #7 of 11 Old 07-21-2014, 08:34 AM
BANNED by Kris
BigFuel's Avatar
Quoted: 43 Post(s)
Does the oil pressure needle come up while cranking?
Matt
'97
-Bean's: 160/100 (FF Injectors), 2/ 6-POS chips (TW & Beans tunes), Overboost controller, E-Fuel
-BANKs: downpipe, full exhaust, gauges, intercooler
-Irate: T-4 kit, IC pipes, 3" Irate Plenums, BASB Turbo
-Stage II trans.
-Mag-Hytec trans. and pumpkin covers
-6637, CCV, IDM, 6.0 Fan, 49-Federal PCM swap, MAP line Mod
-370 Amp alt., 40k trans cooler, ADRENALINE PUMP
-twin on-board air w/ 10 gal. tank
-Oh, and a 2015 F350 6.7L DRW 4x4
BigFuel is offline
post #8 of 11 Old 07-24-2014, 02:38 PM Thread Starter
the oil pressure is coming up at crank.it does have good oil pressure.
post #9 of 11 Old 07-24-2014, 02:44 PM Thread Starter
not really, just basic tools, the computer needs to be fashed so it can be read.
post #10 of 11 Old 10-11-2014, 02:07 PM Thread Starter
problem fixed
I changed out the cam sensor it fix the dieing, thanks everyone
