newbie just bought 97 ccsb 7.3 - Ford Powerstroke Diesel Forum
post #1 of 26 Old 07-16-2014, 01:50 PM Thread Starter
Quoted: 3 Post(s)
I just bought a 97 ccsd 2wd auto powerstroke. Only known mods are a edge tuner and a knn filter. I am going to check the exhaust out to see the size of it.
I think from all I've read I will get a 6637 on the way to replace the knn.
I'd like to do a egt gauge but am unsure about drilling into the exhaust. I worry about the pieces hitting the turbo.
Then how hard is it really to do a down pipe?
JUICED COUPE is offline
post #2 of 26 Old 07-16-2014, 02:17 PM
erics diesel's Avatar
Down pipe isn't bad just have a good sawzall blade to cut it. As far as drilling the manifold do it with the truck idling it will help push the pieces of metal out instead of them getting inside
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #3 of 26 Old 07-16-2014, 04:55 PM Thread Starter
Quoted: 3 Post(s)
How hard to get the bigger one on though
post #4 of 26 Old 07-16-2014, 06:52 PM
Its not bad the new one is 2 pieces
post #5 of 26 Old 07-16-2014, 06:53 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
Just bend the pinch weld with a very large and sturdy bar, and stuff and twist the new one in
Ditch the edge before you eat the trans
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #6 of 26 Old 07-16-2014, 06:54 PM Thread Starter
Quoted: 3 Post(s)
Edge will eat trans?
post #7 of 26 Old 07-16-2014, 08:37 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Yes.......
Transmission, prepare for a rebuild or remove it now and get custom tunes
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #8 of 26 Old 07-17-2014, 02:23 AM Thread Starter
Quoted: 3 Post(s)
Seems odd for a big name to make a product that will eat up trans. What causes this?
post #9 of 26 Old 07-17-2014, 02:35 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Bad shift strategy, and line pressures I'd assume, I've eaten a Trans with one, and so have several others, look for a TS chip with custom tuning or the php hydra with multiple tuners,
Just Kause you've heard of them before you got a diesel, doesn't make them the to to people on a diesel, they make products for everything with obd2, I'd try them on a mustang with a stick shift, but once your into the "diesel scene" you know to who the real big players are, and how to make bigger power then pretty boxes and false claims
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #10 of 26 Old 07-17-2014, 03:20 AM Thread Starter
Quoted: 3 Post(s)
Ive seen edge in many diesels... seems as though they weren't in psds though. Suppose I can ebay it. What about the ts chip with the ts tunes?
