Anyone happen to have an 96-97 EVTM? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-14-2014, 12:44 PM Thread Starter
glovemeister's Avatar
Ordered one the other day and it hasn't arrived.
Was hoping you could cross check the following info for a 97 F350, 7.3, manual trans.
Accelerator Pedal Position Switch:
Grey/White is APP Sensor Signal
Black/White is Signal Return APP
Brown/White is Reference Voltage APP
IVS Switch:
Brown is Voltage (Hot in Start or Run)
Red/Orange (Idle Switch)
Thanks a bunch!
glovemeister is offline
post #2 of 4 Old 07-14-2014, 03:24 PM
the baconator
terryknight's Avatar
Quoted: 149 Post(s)
i would ask matt (bigfuel) he seems to be able to get all that info
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #3 of 4 Old 07-14-2014, 06:30 PM
Patrick Feeley's Avatar
Quoted: 15 Post(s)
Here you go, from the 1997 EVTM:
Grey/White is APP Sensor Signal (PCM connector pin 89)
Black/White is Signal Return APP (PCM connector pin 24). In the 97 EVTM this is called a ground and in 96 and earlier years would have been the Signal Return (Grey/Red) tied in with the other sensors to PCM connector pin 91, but in 97 it was split out separately for some reason.
Brown/White is Reference Output Voltage (PCM connector pin 90)
IVS Switch:
Brown is Voltage (Hot in Start or Run) from underdash fuse 3
Red/Orange (Idle Switch) from PCM connector pin 5 (for Federal 49-state trucks) or PCM connector pin 10 (for 1997 Cali trucks except Super Duty)
Hope that helps! Cheers!
Patrick Feeley is offline
post #4 of 4 Old 07-14-2014, 08:57 PM Thread Starter
Patrick and Terry,
Thanks for your help! Got it figured out and everything is good to go.
