Radiator support question - Ford Powerstroke Diesel Forum
post #1 of 18 Old 07-13-2014, 05:52 PM Thread Starter
pk64f100's Avatar
I have some rot starting on my radiator support down low and think I should replace sooner than later. Does anyone know if $160 support and $18 per bracket left & right so $200 for support and the two mounting brackets. They say they are for 7.3 diesel turbo but says for NOT FOR SUPER COOLED ENGINE (Whate does this mean?) .
***These are new parts. If anyone has a used one I would love, Thanks
VARIOUS MFR ***Part # FO1225121 More Info {#F4TZ16138A} 66.93in L X 5.12in W X 24.41in H
w/diesel engine; Radiator support; w/o Super Cooled Engine
pk64f100 is offline
post #2 of 18 Old 07-13-2014, 06:30 PM
leojr's Avatar
Quoted: 4 Post(s)
Those dimensions don't look right but even if this is the "radiator support" for the OBS, at 24" it is about 6" too short. Do not buy this one until you hear from more informed members.
Denton, TX
I envy those that know exactly which modification to make and in the most logical of sequences. But not enough to trade for my meanderings and misfires.
1996 F250 crew cab/short bed, 4x4, auto PSD, 6637 air filter, interior grab handles, stainless window vents, remote door locks work with engine running mod.
leojr is offline
post #3 of 18 Old 07-13-2014, 06:35 PM
erics diesel's Avatar
There is no aftermarket radiator support for diesel trucks your best bet is to repair yours or find a used one from the south (not very cheap though since they are getting harder to find)
95 f250 eclb 4x4 under construction
96 f250 eclb 4x4 rosewood stage 1 injectors, bully dog 6 position chip, 6637 air filter, idm mod
erics diesel is offline
post #4 of 18 Old 07-14-2014, 12:59 PM Thread Starter
pk64f100's Avatar
F250 & F350 radiator supports the same?
Will the radiator support will fit a f350 if come from a F250 7.3, I found one for $175?
pk64f100 is offline
post #5 of 18 Old 07-14-2014, 01:05 PM
All diesel supports are the same don't matter if its from an f250 or f350
The Following User Says Thank You to erics diesel For This Useful Post:
pk64f100 (07-14-2014)
post #6 of 18 Old 07-14-2014, 01:54 PM Thread Starter
pk64f100's Avatar
is $205 a good price for gradeA used?
is $205 a good price used grade A ?
pk64f100 is offline
post #7 of 18 Old 07-14-2014, 02:22 PM
Phillipjon's Avatar
Quoted: 76 Post(s)
VERY good.
1996 F350 4X4 CCLB SRW
Full Force Stage 1.5-Swamps IDM-Efuel-Bosch 17* HPOP-Melling LPOP-Intercooled-Deleted pedestal-Stancor glow plug relay-1.0 housing-Isspro EV2's-Sky RSK-SD front and rear springs-Tru cool tranny cooler-Built Tranny-CCV mod-6 position chip running TW tunes-6637-3" down pipe to 4" straight pipe-Grab handle mod-Dual lighted visors-3.73 Gears-Warn hubs-SD aluminum rear diff cover-Dual front shocks-295/75/16 Toyo Open Country AT2's
Phillipjon is offline
post #8 of 18 Old 07-14-2014, 02:35 PM
Chop's Avatar
Make sure it's out of a powerstroke and not the IDI version .The powerstroke has a 10 inch drop in the lower cradle .
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
post #9 of 18 Old 07-14-2014, 02:43 PM Thread Starter
pk64f100's Avatar
IDI years from and till?
What yr did they stop installiung IDI's?
pk64f100 is offline
post #10 of 18 Old 07-14-2014, 03:18 PM
The idi version is the same. the late 94 and early 95 use the same radiator as an Idi
