What's the consensus on burning new oil a few quarts a tank? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-12-2014, 12:19 PM Thread Starter
Quoted: 2 Post(s)
I've got a huge assortment of random auto and motorcycle oil laying around that's not going to get used any time soon as it's for vehicles I no longer have (and the current fleet wouldn't appreciate it - my wife's car takes 0W5 or some other water-like oil).
Is there any real harm likely to come from throwing a quart or two of new oil (not used stuff) in the tanks every fillup? It's from about 5W30 to straight 50 weight, with some 80W90 gear oil around as well.
I'm trying to get the stuff sold cheap, but I haven't had much interest, and don't *really* want to just throw it all out in the waste oil bin...
Syonyk is offline
post #2 of 4 Old 07-30-2014, 10:49 AM
sputnik801's Avatar
Quoted: 3 Post(s)
I toss a quart of new oil, 5w30, 10w30 in each full tank. It's good for lubrication of the injectors - or so I've been told. There was a thread with test results from all kinds of oil including 2 stroke, but I could not find it to re-post.
sputnik801 is offline
post #3 of 4 Old 09-02-2014, 06:51 AM
Quoted: 3 Post(s)
That study is the "Spicer" study, I think, and is 8 to 10 years old. A Google will probably find it. It's been widely quoted on Duramax, Cummins and Volkswagen diesel forums, and originated on one of them.
That study does test a variety of additives, including two-cycle ashless oil. The two-cycle oil was shown to increase lubricity in today's "dry" ultra-low-sulfur diesel. But it's important to note that the ashless two-cycle oil is actually designed for burning in an engine, and does not have such potential problems as causing deposits in the top end of the engine.
In contrast, engine oil was not designed to burn in a combustion chamber. It contains a lot of things that are good for bearings and such in the lower end of the engine, but not so good for valves, combustion chambers, etc. in the upper end where deposits can cause problems.
I keep my old unused engine oil for use in oil dispensers for door hinges and other things that can benefit from lubricants of just about any sort. I've got a supply that could last for generations the way I use it.
Airstreamer67 is offline
post #4 of 4 Old 09-03-2014, 10:05 PM
elrojo63's Avatar
Run it.... I used to get "empty" 55 gallon drums of hydraulic oil, gear oil, ATF and basically any other petroleum oil you'd find around machines and drain them out when I cut the tops for burn barrels leading to sometimes 5 gallons in a drum. After I filtered the paint chips and little bit of metal I got in it I'd dump it in the tank like it was diesel. Never had an issue and still run straight veggie oil/whatever oil I can find all summer long in the truck.
1997 PSD Crew Cab Shorty Centurion Flatbed 234k D60 Swap
Leather Interior, built in radar detector, 5 inch dozer stack, DIY exhaust brake/TC lockup
1997 F-250 PSD ZF5 4x4 RCLB 362k SOLD
1953 Clark Carloader Forklift
1996 Subaru Legacy Wagon
2001 Big-Tex 16' Landscape Trailer
2006 Suzuki King Quad 750 27 inch ITP Mudlites
elrojo63 is offline
