OBS ZF5 2nd gear Servo issues - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-11-2014, 10:26 PM Thread Starter
pk64f100's Avatar
My truck will not go into 2nd when downshifting, all tell me it sounds like I have a bad Servo. If the remainder of the trans working fine is it worth repairing the one Servo or should I rebuild entire trans, buy used or buy rebuilt? I have no experience with these trannys and if it is not too difficult to repair I may be able to but if it is really complicated then I would need to take to a trans shop. I live in Carroll County md and looking for a good shop in Carroll Co / Baltimore area / Frankford (near Bethany Beach) Deleware I spend time in all these locations and can bring it to a shop if anyone has good fair shop, let me know. Thanks
pk64f100 is offline
post #2 of 3 Old 07-12-2014, 07:41 AM
dr.deere's Avatar
Quoted: 19 Post(s)
The synchro is bad won't go in or grinds going in. Either way it sounds like a synchronizer. The entire Trans has to come apart. I know it takes a press and some special tools. If it's just the one try double clutching it may help. All of the synchro snare out in my 97 I shift without the clutch and just match rpms. Been that for a year will go many more probably.
Sent from AutoGuide.com App
94 F-250 reg cab 4x4 5spd 7.3 stroke. 3inch downpipe, 4 in exhaust. super duty turbo with 1.0 non wastegated exhaust housing ww2 and 360 thrust kit. Intercooler, MB diesel hpop, driven diesel complete efuel, 6637 air filter, kingpin dana 60.
2012 f250 6.7l powerstroke crew cab long box
Note: The maximum size of your custom image is 500 by 100 pixels or 19.5 KB (whichever is smaller).
dr.deere is offline
post #3 of 3 Old 07-12-2014, 08:07 AM
I rebuilt my tranny last year and needed no specialty tools or a press.
You do need a large range of pullers and separators to get all the bearings and gears off the main shaft.
I then used a toaster oven to heat the new bearings and gears. They slid right on.
Not too difficult, but it's very involved.
williameub is offline
