cali emissions powerstroke injectors - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-11-2014, 09:43 PM Thread Starter
i have a 97 F-250 hd i purchesed baby swappers stage one inj. are they single shot or split shot? and can i run those in my truck with out the chip since the chip wasent programed for cali emissions. my engine just took a dump. have a new long block. I ran thoses inj. in it since last september. would that have any thing to do with having a piston quit working? and where can i find another pcm.
Please help. dont whant to ruin another long block
FOXRIDER76 is offline
post #2 of 7 Old 07-12-2014, 07:46 AM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
You may talk to some of the tuners as they may able to program a chip for single shots on your PCM (DPC-312 if yours is an automatic trans). If you actually wanted to run a 49-state PCM, you would need to re-pin the PCM connector. Read this helpful thread from member BigFuel for some good info: Going from a '97 Cali MME2 to a '96 Federal NAW4
Note that your current PCM is very hard to find, so you may be able to get a good amount for it (don't use it as a core!). Cheers!
Last edited by Patrick Feeley; 07-12-2014 at 07:55 AM. Reason: Added link to BigFuel's thread
Patrick Feeley is offline
post #3 of 7 Old 07-12-2014, 08:59 AM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
What do you mean by "piston quit working" as in it seized up?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #4 of 7 Old 07-12-2014, 08:40 PM Thread Starter
yes it seized up. been getting my long block put back together is there something i need to do to the timing before i get to far. I don't have anyone to help guide me so i thought i'd ask on here.
post #5 of 7 Old 07-12-2014, 08:57 PM Thread Starter
hey patric my ford is F-250 converted to F-350 4x4 auto crew cab short box. I notice that he did that with a two wheel drive will it work on a 4x4?
post #6 of 7 Old 07-12-2014, 08:57 PM Thread Starter
1997 is the year.
post #7 of 7 Old 07-13-2014, 07:39 AM
Quoted: 13 Post(s)
Yes it should work for a 4x4 too. Cheers!
