Possible transmission problem? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-10-2014, 05:37 PM Thread Starter
Possible transmission problem? **SOLVED**
Under what conditions should the torque converter lock? ...I'm not entirely sure if I have a problem here or not. I can feel my torque converter lock when I lay into the throttle but as soon as I let up it unlocks. Is that normal? I'm getting a little over 2000 rpm's at around 60 mph.
Mike
97' F250HD XLT 4x4 | NAPA 6637 | TS Chip | Straight Pipe | CCV Mod | LED lighting | Coolant Filter | 203 Thermostat|
mikeallenbrown is offline
post #2 of 2 Old 10-23-2014, 10:18 AM Thread Starter
Problem Solved!
Some time ago I replaced my incandescent rear lamps with LEDs. What I didn't install was a load resistor (didn't know I needed to). Added a 6ohm 50W load resistor.
What I didn't realize was that the tranny monitors the braking system. Since I had LEDs with no load resistor it wasn't working correctly.
Mike
The Following User Says Thank You to mikeallenbrown For This Useful Post:
Syndicated_cdn (10-23-2014)
