pcm needed - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-10-2014, 08:00 AM Thread Starter
ADMIN AND TECH
SCUFFY828's Avatar
pcm needed
hey fellas , got a obs truck in the shop with the ipr circuit burnt out of the pcm, can not seem to find a computer , truck is a 1996 , ford says its unavailable , they want too much at one of these pcm repair facilities , just thought id see if anybody here knew where one was at or had one
the numbers I have are dpc-202 TEE5 ford number is f5tf-12a650-bjf
any help would be appreciated
ITS STOCK
SCUFFY828 is offline
post #2 of 9 Old 07-10-2014, 08:45 AM
Phillipjon's Avatar
Quoted: 77 Post(s)
Try rock auto
1996 F350 4X4 CCLB SRW
Full Force Stage 1.5-Swamps IDM-Efuel-Bosch 17* HPOP-Melling LPOP-Intercooled-Deleted pedestal-Stancor glow plug relay-1.0 housing-Isspro EV2's-Sky RSK-SD front and rear springs-Tru cool tranny cooler-Built Tranny-CCV mod-6 position chip running TW tunes-6637-3" down pipe to 4" straight pipe-Grab handle mod-Dual lighted visors-3.73 Gears-Warn hubs-SD aluminum rear diff cover-Dual front shocks-295/75/16 Toyo Open Country AT2's
Phillipjon is offline
post #3 of 9 Old 07-10-2014, 10:22 AM
Quoted: 50 Post(s)
TEE5 ...-BJF indicate a 1995 PCM. If I were guessing, I'd say the 1996 equivalent would be a NAW5 F6TF-12A650-AYF . But double-check the model year, based on the VIN. But any non-California truck automatic PCM should work. PCM codes are here: PCM Codes - 1994-1997 Power Stroke FAQ . You could try Car-Part.com--Used Auto Parts Market , but the stoopid site design does not let you select mutiple options in a single search.
Check the classifieds, part-out section esp., here and at the other PSD-related forum sites.
madpogue is online now
post #4 of 9 Old 07-10-2014, 10:44 AM
I paid $150 from Napa to have my PCM rebuilt when I burned it out last september... Mind you this was through Napa Canada but worth a shot... Ford wanted $900 for a PCM for my MLE1 pcm
matt-jenkins is offline
post #5 of 9 Old 07-10-2014, 06:05 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
Originally Posted by Phillipjon View Post
Try rock auto
That would be my advice as well. I got one for my 94 from them. Then they were $115, now they $118 plus $68 refundable core IIRC. Cheers!
Patrick Feeley is offline
post #6 of 9 Old 07-15-2014, 05:01 AM Thread Starter
ADMIN AND TECH
SCUFFY828's Avatar
thanks for all the input guys , I cant believe a pcm has been this hard to get my hand s on , thanks again, ill look into some of your ideas
ITS STOCK
post #7 of 9 Old 07-15-2014, 05:12 AM
Quoted: 50 Post(s)
Did you determine whether the truck is a 1995 or 1996?
post #8 of 9 Old 07-15-2014, 05:52 AM Thread Starter
ADMIN AND TECH
SCUFFY828's Avatar
yea def a 1995 model, id say a 1996 or even a 97 auto trans pcm would work , around here nobody has any of these truck in the parts yards
ITS STOCK
post #9 of 9 Old 07-15-2014, 07:49 AM
Quoted: 50 Post(s)
PCM is easy to ship. Just get on car-part.com and search by distance. Bummer with car-part.com is that you can't search for multiple options in one search, you have to keep going back to your search, and pick another PCM type. IIRC, the part name in the drop-down is "Engine Computer".
