Just got worst news - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 16 Old 07-09-2014, 03:00 PM Thread Starter
pk64f100's Avatar
Just got worst news
I just got the inspection report from the local Mr Tire state inspection in Mt Airy md and they picked the truck apart like they were trying to suck every dime out of me. Everything from a sticker on the windsheild, driver seat will not adjust (fits me fine), says that the tires are the incorrect range They are E range, no muffler( truck is quiet and has down pipe and ex brake), about 10 -0 15 other items. Worst is I have nice rims on truck with new Lt 305 70 R16 and they say that I need new rims and smaller tires that came on the truck to pass something like 225's what a bunch of BULL****! I sure wish i knew someone who could help me get my truck inspected, I use to have a friend who would inspect and have me fix safety items not a frickin sticker or seat adjustement, these guys here where I live are unbelievable, this stinks it took every penny i had to buy the old truck and tires and now this, unreal.I really do not want to wait till January when I can get historic tags but if I do that will be worse case scenario.
Maryland inspections really suck, unbelievable how they just want to suck every penny out of you for no reason!
pk64f100 is offline
post #2 of 16 Old 07-09-2014, 03:51 PM
Quoted: 2 Post(s)
You know, if you hadn't spent so much money on the truck, the state would be able to take more of your money to redistribute as they see fit instead of you wasting it on a truck...
*sigh*
You should be able to do a lot of the work needed yourself, though. The sticker on the windshield & seat adjustment should be pretty straight forward. Throwing a muffler looking bulge into the exhaust shouldn't be too hard either, depending on how it's set up. Should be quite cheap for a shop to weld you up some flanges and a test pipe you can swap out for a muffler when needed.
Also, having a thread title to the tune of "Maryland Inspection Woes" or such would help get local people to answer you more specifically. You could also check with people in a local group out there - I'm sure you're not the first person to get harassed by the Maryland Motor Mafia.
Syonyk is offline
The Following User Says Thank You to Syonyk For This Useful Post:
pk64f100 (07-09-2014)
post #3 of 16 Old 07-09-2014, 04:33 PM Thread Starter
pk64f100's Avatar
Thanks, How can i change thred?
Do I have to start a new thread with the Md state inspection woes or can i edit this one? Thanks
pk64f100 is offline
post #4 of 16 Old 07-09-2014, 04:44 PM
daddyusmaximus's Avatar
Quoted: 12 Post(s)
I'm so glad I live in a free state.
99 F-250 Super Duty, 4X4, CCSB.
AKA: The Liberty Wagon.
daddyusmaximus is offline
The Following 3 Users Say Thank You to daddyusmaximus For This Useful Post:
Heavy_GD (07-09-2014), kinnisoj (07-09-2014), pk64f100 (07-09-2014)
post #5 of 16 Old 07-09-2014, 05:17 PM
Quoted: 2 Post(s)
Find a friend...swap out parts for a reinspection?
7point3 noob is offline
post #6 of 16 Old 07-09-2014, 06:29 PM
gone6.0's Avatar
Quoted: 21 Post(s)
Don't know about MD, but WV allows two sizes above factory option on tires, Example my truck came with 245/75/16, factory option is 265/75/16. the tires I have are legal at 285/75/16.
2004 F250, SCSB, APR studs, Banks intercooler, Edge Insight, SCT with tune from Eric, atlas 40, deleted, 2" leveling kit, coolant filter, 6.4 banjo bolts with blue spring, Harpooned, Nathan K5LA. Nations 190 amp alt.
Twin Viair 480C's. BOSS superduty 8' poly plow.
gone6.0 is offline
post #7 of 16 Old 07-09-2014, 07:18 PM
jjvizinat's Avatar
I lived in MD the last 3 yrs and heard the horror stories of guys owning diesels there. Mines registered in Louisiana (thank God) but cant imagine that kind of thing ever happening to me. I'd lose it.
2006 F-250 King Ranch
Headstuds, OEM gaskets, Updated Oil Cooler, Stand Pipes, Dummy Plugs, STC Fitting (Trucks Unlimited, NC)
35" Toyo Open Country M/T
Coolant Filter with ELC Coolant
Blue Fuel Spring Upgrade
S&B Cold Air Intake
EGR Delete
SCT X4
Nice and clean
jjvizinat is offline
post #8 of 16 Old 07-09-2014, 08:23 PM
PSMstroker's Avatar
Wow that's pretty communist man. I feel very lucky to live in WA were I could just remove the cab and as long as I have head lights, turn signals, bumpers, license plate and a seat belt it's all good. It would be like a giant go kart
96 power stroke
extended cab long bed
4 wheel drive
4" Diamond Eye Performance exhaust system
Auto Meter sport comp Pyro, tranny, and boots
Edge EZ
S&B intake
FPR shim
Banks transcomand
Banks ottamind tuner
150 DBA 150psi train horns
5 gallon air tank and Viair 480c compressor
2.5" tuff country lift kit
285/75/16 goodyear wrangler duratracs
E4OD automatic that is fresh.
PSMstroker is offline
post #9 of 16 Old 07-09-2014, 08:24 PM
hansel's Avatar
Quoted: 94 Post(s)
That's BS in my book
The Government loves too take, and give (too those who don't deserve it)
But you can't mod a truck in Maryland?? Thanks for the warning, I'm never moving there
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #10 of 16 Old 07-09-2014, 09:36 PM
Quoted: 8 Post(s)
Man that SUCKS. I would be in jail right now if that happened to me. So, props for staying cool. I thought my annual Colorado government screwing was bad. I have to have a dyno test here every year and a inspection for $50. Basically give us $50 and we look to make sure you have a cat and your smoke isn't too black.
I would move to a freer state. Lots of construction jobs here in Colorado. Your truck would pass inspection no problem out here.
1997 Crew Cab Long Bed 4X4 (DRW Conversion) Auto. 280K miles
Stainless Irate Bellowed Up Pipes
Fresh Turbo with 1.0 Housing & Wicked Wheel II, 3" downpipe with 4" exhaust, Intercooled, 6.0 Fan, 39 gal rear fuel tank + 70 gal Transfer Flow in the bed, Hydroboost, Completely New Suspension (Springs, Shocks, Bushings),08 Rear Diff Cover, Baby Swamps, Hydra Chip with Swamps Tunes, and Swamps IDM, Dually Swap, Tru-Trac locker in the rear, Red Head Steering Box and Borgeson Steering Shaft
ChallengerRV is offline
